SMX2200XLRT2UN
SMX2200XLRT2UN
    TRIPPLITE
    SMARTPRO 230V 2200VA 1920W LINE-
SMX2200XLRT2UN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 230V 2200VA 1920W Line-Interactive Sine Wave UPS, 2U, Extended Run, WEBCARDLX, LCD, USB, DB9 MODEL NUMBER: SMX2200XLRT2UN Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● Maintains continuous 230V nominal output during brownouts and overvoltages ● Pre-installed WEBCARDLX with latest version of PADM20 supports Auto Probe feature ● Easy-to-read LCD allows realtime monitoring of voltage, battery status and other data Applications ● Protect your small network server and other network components against power surges, line noise, brownouts, overvoltages and blackouts Offers complete line-interactive power protection for professional applications, including retail, casino and hotel management. ● Operate essential equipment during short-term power outages using battery backup power Features ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Connect high-end security systems, casino gaming machines or digital signage in a small network 2.2kVA/1.92kW/230V Battery Backup for PC Networks, Security Systems or Digital SignageThe SmartPro® line-interactive SMX2200XLRT2UN UPS system with AVR provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The eight-outlet 230V battery backup with 0.9 power factor is ideal protection for small networks, wiring closets, security systems, telecom, high-end PC gaming, digital signage equipment and other professional applications, including retail, casino and hotel/motel management. Reliable, Expandable Battery Backup Keeps You Operational Through Power OutagesThe fieldreplaceable, hot-swappable internal battery provides 11.9 minutes of support at half load (960W) and five minutes at full load (1920W), allowing you to work through short power failures and giving you enough time to safely save files and shut down your system in case of a prolonged blackout. For mission-critical applications demanding scalable extended runtime, the UPS supports external battery packs, such as BP48V27-2US (sold separately). WEBCARDLX Network Interface Offers 24/7 Remote Access for Monitoring and ControlThe built-in WEBCARDLX with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities, including customizable dashboard graphs to fit user preferences. The PADM20 upgrade and PowerAlert Element Manager (PAEM) software form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations. PADM20’s Auto Probe feature allows a UPS with switched loads to automatically reboot devices if a network communication failure is detected. 8 Outlets Protect Your Connected ComponentsEight C13 outlets provide battery backup, 350 joules of surge protection and voltage regulation for your crucial components. Two independently switched singleoutlet load banks enable both scheduled and real-time remote rebooting and load shedding. Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage ConditionsAVR protects your equipment from incremental hardware damage, data loss and performance problems caused by brownouts and overvoltages. The SMX2200XLRT2UN can correct brownouts as low as 158V and overvoltages as high as 278V back to nominal 230V power continuously, all while keeping the battery fully 1/6 Package Includes ● SMX2200XLRT2UN 230V 2200VA 1920W Line-Interactive UPS with 8 Outlets ● WEBCARDLX network management card ● USB cable ● DB9 cable ● EPO cable ● (3) C13-to-C14 AC power cords ● Rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States charged and ready to take over in case of power failure. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterThis UPS system filters out disruptive electromagnetic and radio frequency interference that can inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Designed for High Efficiency to Help You Save Money and Protect the EnvironmentA 98% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. Silenceable Alarm and Easy-to-Read LCD Keep You Informed Around the ClockThe front-panel LCD lets you monitor important data, such as load level, power factor, voltage, battery charge and estimated runtimes. It rotates for comfortable viewing in both rack and tower configurations. The audible alarm sounds for power failure, low battery and overloads. You may silence it using the built-in switch or disable it. Advanced Communications Ports Allow for Automatic Saves and ShutdownsRS-232 and HIDcompliant USB ports connect to a computer running free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. The EPO port supports emergency shutdown in large facilities. Cables are included. Versatile Installation OptionsHardware is included for mounting the SmartPro UPS system in 2U of space in an EIA-standard 19-inch 4-post rack. Using optional mounting accessories (sold separately), you can adapt the SMX2200XLRT2UN for 2-post (2POSTRMKITWM), front-rail (UPSHDEARKIT), 4-post short-depth (4POSTRAILKITWM), tower (2-9USTAND) or wall mounting (2POSTRMKITWM). Specifications OVERVIEW UPC Code 037332256430 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10.7A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C20 inlet UPS Input Connection Description IEC320-C20 input connection accepts a variety of detachable cordsets to match country or site-specific wall receptacles Input Circuit Breakers 15A OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1920 Output Capacity (kW) 1.92 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0.87 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -15%, +6% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 3 C13 to C14 output power cables Load Management Receptacles Two switchable single-outlet C13 load banks Hot-Swap PDU options PDUBHV20 (2U / 6 C13, 2 C19 outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (8) C13 Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (1920W) Runtime Half Load (min.) 11.9 min. (960W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 158 to 278 Overvoltage Correction Voltage reduction of 12% applies when input is between 244-278V Undervoltage Correction Voltage boost of 12% applies when input voltage is between 183-206V 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Severe Undervoltage Correction Voltage boost of 24% applies when input voltage is between 158-182V USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 350 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 58.42 Minimum Required Rack Depth (inches) 23 Minimum Required Rack Depth with External Battery Pack (cm) 67 Minimum Required Rack Depth with External Battery Pack (in.) 26.5 Minimum Required Rack Depth without External Battery Pack (cm) 55 Minimum Required Rack Depth without External Battery Pack (in.) 21.75 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 495 Primary UPS Height (mm) 89 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 8.70 x 24.20 x 21.50 Shipping Weight (kg) 36.76 UPS Housing Material Steel UPS Power Module Dimensions (hwd, in.) 3.50 x 17.50 x 19.50 UPS Power Module Weight (kg) 31.18 UPS Power Module Weight (lbs.) 68.75 Unit Weight (lbs.) 68.750 Unit Weight (kg) 31.18 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 161 AC Mode Efficiency Rating (100% Load) 98% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards  WEBCARDLXE  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB, DB9 and EPO cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card included Communications Interface DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 6 ms. (AC to DC) / 1 ms. (DC to AC) Low Voltage Transfer to Battery Power (Setpoint) 158V High Voltage Transfer to Battery Power (Setpoint) 278V FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Details Back panel grounding lug APPLICATIONS UPS Applications Large Network; High-End Desktop/Small Network STANDARDS & COMPLIANCE Product Certifications GOST (Russia) Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMX2200XLRT2UN 价格&库存
很抱歉,暂时无法提供与“SMX2200XLRT2UN”相匹配的价格&库存,您可以联系我们找货
