1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 1U Digital Temperature Sensor,
Blanking Panel, LCD
MODEL NUMBER: SR1UPNLTEMP
Highlights
Cold-rolled steel panel fills
unused rack space to give
enclosure a clean, sleek look
Protects rack-mount equipment
by improving airflow and cooling
efficiency
Included temperature sensor
identifies hot spots within the
rack up to 6-ft. (1.83 m) away
Front-panel LCD displays rack
temperature in Fahrenheit or
Celsius
Mounts easily into 1U of space
in your EIA-standard 19 in. rack
enclosure
Applications
Close off unused rack spaces to
prevent hot air from recirculating
around equipment
Monitor rack temperature at a
glance in either Fahrenheit or
Celsius
1U blanking panel with temperature sensor measures environmental conditions within your rack and
displays degrees in F° and C°.
Package Includes
Features
1U Blanking Panel with Temperature Sensor Helps Improve Rack Cooling EfficiencyThis cold-rolled
steel SmartRack® blanking panel with a black powder-coated finish fills 1U of unused space in your EIAstandard 19-inch rack. Not only does this give your rack a sleek, clean look, but it also protects your
valuable equipment by improving airflow. By closing off unused rack openings, this blanking panel
prevents hot air from recirculating through open spaces. This reduces operating costs, improves
performance and provides longer lifespans for your equipment.
Helps You Precisely Measure Your Rack Temperature, Even High UpThe SR1UPNLTEMP helps you
notice hot spots at the top of your rack with the included temperature sensor. The 6-ft. (1.83 m) sensor
reaches every crack and crevice within your rack and finds hot spots. The sensor accurately measures the
rack temperature within 2°F and 1°C and a range of -58°-302°F and -50°-150°C.
LCD Indicator Lets You Keep a Close Watch on Environmental ChangesA front-panel LCD lets you
monitor the rack temperature in either Fahrenheit or Celsius. One front rocker switch flips between °F and
°C. The other turns the SR1UPNLTEMP on and off. The included 12V DC power supply features a 6-ft.
(1.83 m) cord and NEMA 1-15P plug that connects to an AC wall outlet, PDU or UPS system.
Specifications
OVERVIEW
UPC Code
037332240613
Accessory Type
Temperature Sensor
Accessory Class
Rack Accessories
INPUT
1/2
SR1UPNLTEMP 1U Blanking
Panel
Temperature sensor
12V DC power supply with 6-ft.
plug
Owner’s manual
Cleveland, OH 44122
United States
Nominal Input Voltage(s) Supported
120V AC
Nominal Input Voltage Description
120V AC 60 Hz
Input Connection Type
NEMA 1-15P
Input Plug Features
NEMA 1-15P
Input Cord Length (ft.)
6
Input Cord Length (m)
1.83
PHYSICAL
Rack Height
1U
Shipping Dimensions (hwd / in.)
7.48 x 20.35 x 4.21
Shipping Weight (kg)
1.80
Unit Dimensions (hwd / in.)
1.710 x 17.300 x 3.750
Unit Dimensions (hwd / cm)
4.34 x 43.94 x 9.52
Unit Weight (lbs.)
2.460
Unit Weight (kg)
1.12
FEATURES & SPECIFICATIONS
Sensing Capability
Temperature
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SR1UPNLTEMP”相匹配的价格&库存,您可以联系我们找货
