SR4POST58HD
SR4POST58HD
    TRIPPLITE
    金属 - 钢 开放式机架 开放式机架,双框架 24.000" 长 x 35.250" 宽 x 107.500" 高(609.60mm x 895.35mm x 2730.50mm) 黑色
SR4POST58HD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 58U Heavy-Duty 4-Post SmartRack Open Frame Rack - Organize and Secure Network Rack Equipment MODEL NUMBER: SR4POST58HD Highlights ● 58U Heavy-Duty 4-post open frame rack ● Black steel with square, numbered mounting holes ● Toolless button holes to accept PDUs or cable managers Package Includes Description Tripp Lite's 58U Heavy-Duty 4-Post Open Frame Rack helps IT managers organize their equipment array and provides fast, easy access to installed IT equipment. The SR4POST58HD is a simple solution for housing IT equipment in secure environments and other areas that don't require a lockable rack solution. This 58U rack features heavy-duty cold-rolled steel construction with a black powder-coated finish for durability. It supports stationary loads up to 3000 lbs (1360.8 kgs). The SR4POST58HD comes with all the hardware required for assembly and has a self-squaring design with bolt-down provisions. For highdensity applications, multiple units can be bolted together side by side. The open design of the SR4POST58HD provides unobstructed airflow and easy access to equipment and cabling. It has numbered, square-hole mounting positions for easy installation of standard 19-inch rack equipment. The SR4POST58HD supports equipment depths up to 35 inches. This rack also accommodates toolless button-hole mounting for vertical PDUs and cable managers. The optional SRCASTERHDKIT Heavy-Duty Rolling Caster Kit adds mobility to the SR4POST52HD. The rack supports rolling loads of 3000 lbs (1360.8 kgs). The SR4POST58HD also supports optional side panels with the SR58SIDE4PHD, a set of two half-size side panels and a third smaller panel that add a finished look to end-of-row racks in your data center. Features ● Weight capacity of 3000 lbs (1360.8 kgs) stationary ● Supports equipment depths up to 35 inches ● Textured, black powder coat finish ● Heavy-duty cold-rolled steel construction ● Numbered mounting positions ● Bolt down provisions ● Self-squaring design ● Easy assembly ● Optional SRCASTERHDKIT heavy-duty caster kit permits mobile use of 3000 lbs (1360.8 kgs) rolling loads ● Optional SR58SIDE4PHD side panels for end-of-the-row aesthetics 1/3 ● SR4POST58HD Heavy-Duty 4Post Open Frame Rack ● Installation hardware ● (2x) PDU/Cable management brackets ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332185815 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Open-Frame PHYSICAL Color Black Rack Height 58U Rack Depth Standard Maximum Device Depth (cm) 89.54 Maximum Device Depth (in.) 35.25 Maximum Device Depth (mm) 895 Shipping Dimensions (hwd / in.) 6.75 x 9.50 x 111.25 Shipping Dimensions (hwd / cm) 17.14 x 24.13 x 282.58 Shipping Weight (lbs.) 130.00 Shipping Weight (kg) 58.97 Unit Dimensions (hwd / in.) 107.500 x 24.000 x 35.250 Unit Dimensions (hwd / cm) 273.05 x 60.96 x 89.54 Unit Weight (lbs.) 125 Unit Weight (kg) 56.70 Weight Capacity - Stationary (kg) 1,361 Weight Capacity - Stationary (lbs.) 3000 Number of Vertical Mounting Rails 4 Assembly Required Yes FEATURES & SPECIFICATIONS Pre-Installed Casters No STANDARDS & COMPLIANCE Product Certifications IEC 60297-3 Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR4POST58HD 价格&库存
很抱歉,暂时无法提供与“SR4POST58HD”相匹配的价格&库存,您可以联系我们找货
