SRCABLEVRT3FC
SRCABLEVRT3FC
    TRIPPLITE
    支架 垂直电缆管理器
SRCABLEVRT3FC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Capacity Vertical Cable Manager - Double Finger Duct, Yellow, 6 ft. (1.8 m) MODEL NUMBER: SRCABLEVRT3FC Highlights ● Neatly organizes fiber, copper and coaxial cables in your enclosure or open frame rack ● High-capacity 3 in. width allows installation and routing of larger cable bundles ● High-visibility yellow steel helps your bundle stand out in a crowded rack ● Fingers and pass-through holes allow easy routing and separation of bundled cables ● Features button mounts for toolless installation in an EIAstandard 19 in. rack Applications Vertical fiber cable manager routes and organizes network cabling through your 19 in. rack while maintaining proper bend radius. Features Extra-Wide 6 ft. Vertical Cable Manager Keeps Your Rack Looking Neat and Organized Easy to mount along the side of your rack cabinet or open frame rack, the SmartRack® SRCABLEVRT3FC neatly organizes fiber optic, copper and coax cable bundles. This vertical manager maintains proper bend radius to eliminate stress on the cables connecting your network devices. Fingers on either side allow convenient access to cabling for routing and separation of bundles. The high-capacity three-inch (7.6-centimeter) width allows the installation and routing of large fiber cable bundles. The cable manager is made from high-visibility yellow steel to help you identify its contents in a crowded rack. 2 ft. Sections Allow Flexibility in Mounting The SRCABLEVRT3FC comes in three two-foot (0.6-meter) sections to give you more installation options. No hardware is required for toolless 0U vertical installation in an EIA-standard 19-inch rack. In addition to standard rack enclosures, this cable manager is ideal for open frame racks and larger cabinets from 42U to 48U. Specifications OVERVIEW UPC Code 037332240026 Accessory Type Cable Management Accessories PHYSICAL Color Yellow Unit Dimensions (hwd / in.) 24.450 x 4.400 x 5.310 Unit Dimensions (hwd / cm) 62.10 x 11.18 x 13.49 1/2 Keep fiber, copper and coax cable organized and tidy within a rack enclosure or open frame rack in your network closet, computer room or server room Package Includes (3) Vertical Fiber Cable Managers, Yellow, 2 ft. (0.6 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (lbs.) 5 Unit Weight (kg) 2.27 Cable Manager Form Factor Vertical WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SRCABLEVRT3FC 价格&库存
很抱歉,暂时无法提供与“SRCABLEVRT3FC”相匹配的价格&库存,您可以联系我们找货
