SRCOOL12K
SRCOOL12K
    TRIPPLITE
    PORTABLE AIR COND 12000 BTU
SRCOOL12K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Portable AC Unit for Server Rooms - 12,000 BTU (3.5 kW), 120V MODEL NUMBER: SRCOOL12K Highlights ● 12,000 BTU (3.5kW) of cooling capacity protects vital equipment against overheating ● IT-grade hot air exhaust fan stays effective even under a high heat load ● Built-in evaporator for drip-free operation—no need to empty water collection tanks ● Self-contained design with no plumbing or special circuits—easy setup by almost anyone ● 100% duty cycle keeps your equipment constantly cool with no downtime Applications Use Tripp Lite's SRCOOL12K portable air conditioner to cool small server rooms and network closets, or to spot cool a hot rack in a data center. Features Portable Close-Coupled Cooling with Customer-Inspired Upgrades for Better Performanceawardwinning SRCOOL12K, now in its second generation, is a portable, compact, self-contained air conditioning unit designed for server rooms, small network closets, back offices and other areas with heatsensitive network switches and servers that facility air conditioning can’t reach. Design improvements based on customer feedback include upgraded commercial-grade components designed to last longer, including an upgraded hot air exhaust fan. The SRCOOL12K Gen 2 also boasts robust packaging for better protection from shipping damage and an updated two-year warranty. 12,000 BTU of Cooling Power Protects Your Equipment Against Hazardous High HeatThis SmartRack® server room air conditioner pumps 12,000 BTU (3.5kW) of cooling into your IT environment to help prevent shutdowns, malfunctions and other failures caused by overheating or fluctuating temperatures. It uses environmentally friendly R410A refrigerant to comply with worldwide standards. An easy-to-read control panel with diagnostic LEDs provides convenient local management. Rack/Spot AC Unit Focuses Cold Air Where It’s Most NeededClose-coupled air-conditioning delivers cold air near heat loads to discourage recirculation and increase energy efficiency. An included 71-inch flexible hose lets you aim the cold air to a specific spot, such as an overheated server rack or an equipment hot spot. Hot air exits through a window or drop ceiling via an included exhaust kit. An upgraded hot air exhaust fan maintains effectiveness even under a high heat load. The unit also dehumidifies and filters the air, providing better air quality that can enhance operating conditions and equipment reliability. Commercial-Grade Components for Reliable PerformanceWith a 100-percent duty cycle, the SRCOOL12K can run continuously without costly downtime. It uses copper tubing that is stronger than the aluminum tubing used in most consumer cooling units. The copper allows higher pressures and better weld joints to stand up to the constant vibration of the running compressor. Built-In Evaporator Ensures No Water Collection Tank to EmptyThe evaporator expels the condensed water through the directional exhaust duct, eliminating the need for a drain tube, drain pan or water collection tank and saving you time and money. No external condenser, refrigerant piping or professional maintenance is required for simple operation. Upgraded firmware allows the compressor to cycle on and off while the evaporator fan stays on to prevent icing in high-humidity environments. 1/4 ● Cool an overheated network cabinet, server rack or EdgeReady™ micro data center ● Use the included louvered vent to cool a small server room, back office or network closet, up to 500 sq. ft. ● Add supplemental cooling when additional equipment overwhelms existing cooling systems Package Includes ● SRCOOL12K Portable Server Rack AC Unit, Gen 2 ● Louvered front vent insert ● Duct adapters ● Cold-air flexible duct ● Hot-exhaust duct ● Window/drop-ceiling heatventilation kit ● Drainage plugs ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Add an Optional Remote Management Accessory for 24/7 Monitoring and ControlInstall the optional SRCOOLNETLX network module (sold separately) to monitor temperatures, receive alerts, review logs and control settings from anywhere, anytime, via SNMP, web browser, SSH, telnet or command line interface. The built-in LX Platform’s PowerAlert® Device Manager provides a single interface to cycle the connected air conditioner on and off, adjust its fan speed, change its target set point temperature and switch to dehumidification mode. Designed for Simple Plug-and-Play Installation by Almost AnyoneThe self-contained SRCOOL12K requires no disruptive installation projects or costly service calls from plumbers or HVAC specialists. It rolls on four casters into a compact 12 x 20 inch area. The 6-foot power cord’s NEMA 5-15P plug with leakage current protection connects to a standard AC outlet. The unit is programmed to restart automatically after power failures, and a built-in timer allows unattended shutdown and startup. An upgraded motor-start capacitor with a larger capacity ensures a dependable startup. 2-Year Warranty*The SRCOOL12K is backed by a robust 2-year warranty, ensuring reliability and performance. Note: 2-year warranty available in U.S. and Canada only. One-year warranty available elsewhere. Specifications OVERVIEW UPC Code 037332145765 INPUT Electrical Consumption (Max) 1400 Watts Nominal Input Voltage(s) Supported 120V AC Nominal Input Voltage Description 120V AC 60 Hz Input Connection Type NEMA 5-15P Input Plug Features NEMA 5-15P Voltage Compatibility (VAC) 120 Input Frequency 60 HZ Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 COOLING Cooling Type Active Airflow Evaporator = 329 CFM / Condenser = 311 CFM Cooling Capacity (BTUs) 12000 Cooling Capacity (kW) 3.5 Equivalent Room Size 24 sq. m (258.33 sq. ft.) USER INTERFACE, ALERTS & CONTROLS Front Panel LEDs Touch sensitive control panel with multiple LEDs and numerical temperature readout 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction ABS Form Factors Supported Tower Shipping Dimensions (hwd / in.) 29.00 x 15.40 x 33.10 Shipping Dimensions (hwd / cm) 73.66 x 39.12 x 84.07 Shipping Weight (lbs.) 78.46 Shipping Weight (kg) 35.59 Unit Dimensions (hwd / in.) 30.630 x 11.810 x 19.880 Unit Dimensions (hwd / cm) 77.8 x 30 x 50.5 Unit Weight (lbs.) 71.36 Unit Weight (kg) 32.37 FEATURES & SPECIFICATIONS Refrigerant R410a (Environmentally friendly, Non ozone depleting) Refrigerant Amount 15.5 oz Air Supply Tube Length 71 inches Air Exhaust Tube Length 118 inches Air Exhaust Tube Diameter 5.16 inches Compressor Type Rotary Dehumidifier 2.5 liters / hour Sound Level (Noise) 57dB Amp Draw Nominal 10.5A STANDARDS & COMPLIANCE Product Certifications CSA (Canada); UL 484 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 2-year limited warranty Product Warranty Period (Latin America) 1-year limited warranty Product Warranty Period (International) 1-year limited warranty Product Warranty Period (Mexico) 1-year limited warranty Product Warranty Period (Puerto Rico) 1-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SRCOOL12K 价格&库存
很抱歉,暂时无法提供与“SRCOOL12K”相匹配的价格&库存,您可以联系我们找货
