SRCTMTR600SH
SRCTMTR600SH
    TRIPPLITE
    SHORT RISER PANELS FOR HOT/COLD
SRCTMTR600SH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Short Riser Panels for Hot/Cold Aisle Containment System - Standard 600 mm Racks, Set of 2 Highlights ● Riser panels designed for standard-width 600 mm rack enclosures ● Fill gap between rack cabinets and aisle containment system’s telescopic beams ● Minor assembly required using the included hardware MODEL NUMBER: SRCTMTR600SH Applications ● Provide a semi-airtight seal to prevent hot and cold air from mixing within a contained aisle in your data center or server room System Requirements ● SRCTMTTLBM Beam Kit ● SRCTMTFRM Frame End Kit ● SRCTMTSDD Sliding DoubleDoor Kit ● SRCTMTCVR600 Static Roof Panel Kit Aisle Containment System keeps hot and cool air separated for better temperature control and equipment performance in hot aisle/cold aisle configurations. Package Includes Features Riser Panels Designed for Standard-Width 600 mm Server RacksThese SmartRack® riser panels attach to the underside of the aisle containment system’s upper support beams. This is to fill the gap between the telescopic beams (SRCTMTTLBM, sold separately) and your rack cabinets. All necessary installation hardware is included. The 3U SRCTMTR600SH measures 600 millimeters (24 inches) wide and 133 millimeters (5.2 inches) high to fit 45U standard-width rack enclosures. Aisle Containment System Manages Airflow for More Cooling EfficiencyUpon installation in your data center or server room, the modular, easy-to-assemble Aisle Containment System contains the air in a hot aisle or cold aisle, essentially creating a room within the aisle, while still keeping the aisle accessible. No costly contractor or HVAC specialist is required to install the system, which can be expanded or adapted to meet your needs. Assorted frame kits, beam kits, sliding double-door kits, roof panel kits and adapter riser panel kits (all sold separately) are necessary to assemble a hot or cold Aisle Containment System that accommodates the dimensions of your aisle and the rack enclosures within it. Specifications OVERVIEW UPC Code 037332214362 Accessory Type Cooling Accessories Aisle Containment System Component Type Riser Panel PHYSICAL Color Black 1/2 ● (2) Riser panels ● (2) M6 x 16 screws ● (2) M6 hex nuts ● (4) M6 x 12 self-tapping screws ● (6) M6 washers ● Installation guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 8.27 x 28.62 x 5.71 Shipping Weight (kg) 3.10 Rack Compatibility 600 mm (Standard) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2024 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SRCTMTR600SH 价格&库存
很抱歉,暂时无法提供与“SRCTMTR600SH”相匹配的价格&库存,您可以联系我们找货
