SRFAN1UTEMP
SRFAN1UTEMP
    TRIPPLITE
    支架 盲板
SRFAN1UTEMP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1U Blanking Panel with Temperature Sensor and High-Performance Fans MODEL NUMBER: SRFAN1UTEMP Highlights ● Cools rack equipment to boost system performance and avoid costly downtime ● Pre-installed high-performance 4 in. 12VDC fans push cool air through the rack ● Included temperature sensor identifies hot spots within the rack up to 6-ft. (1.83 m) away ● Front-panel LCD displays rack temperature in Fahrenheit or Celsius ● Mounts easily into 1U of space in your EIA-standard 19 in. rack enclosure Applications 1U blanking panel blows cool air through your rack enclosure to keep valuable equipment functioning efficiently without costly breakdowns. Features 1U Blanking Panel Helps Improve Rack Cooling Efficiency and Optimize AirflowThis cold-rolled steel SmartRack® blanking panel with a black powder-coated finish fills 1U of unused space in your EIAstandard 19-inch rack. Not only does this give your rack a sleek, clean look, but it also protects your valuable equipment by improving airflow and cooling efficiency. This reduces operating costs, improves performance and provides longer lifespans for your equipment. High-Performance Fans Keep Equipment Cool in Crowded Server Rack EnclosuresThree built-in four-inch 12VDC fans mount into the rack and pull cool air from the outside. The included 12V DC power supply features a 6-ft. (1.83 m) cord and NEMA 1-15P plug that connects to an AC wall outlet, PDU or UPS system. Helps You Precisely Measure Your Rack Temperature, Even High UpThe SRFAN1UTEMP helps you notice hot spots at any section of your rack with the included temperature sensor. The six-foot sensor reaches every crack and crevice within your rack and finds hot spots that need to be cooled with the fans. The sensor accurately measures the rack temperature within 2°F and 1°C and a range of -58°-302°F and -50°-150°C. LCD Indicator Lets You Keep a Close Watch on Environmental ChangesA front-panel LCD lets you monitor the rack temperature in either Fahrenheit or Celsius. One front rocker switch flips between °F and °C. The other turns the SRFAN1UTEMP on and off. Specifications OVERVIEW UPC Code 037332240644 Accessory Type Temperature Sensor Accessory Class Cooling Accessories 1/2 ● Direct cool air at servers, switches and other rack components to boost performance and extend operating life ● Monitor rack temperature at a glance in either Fahrenheit or Celsius ● Close off unused rack spaces to prevent hot air from recirculating around equipment Package Includes ● SRFAN1UTEMP 1U Blanking Panel ● Temperature sensor ● 12V DC power supply with 6-ft. (1.83 m) cord and NEMA 1-15P plug ● Rack-mounting hardware ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 120V AC Nominal Input Voltage Description 120V AC 60 Hz Input Connection Type NEMA 1-15P Input Plug Features NEMA 1-15P Voltage Compatibility (VAC) 120 Input Frequency 60 Hz Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 COOLING Cooling Type Active PHYSICAL Rack Height 1U Shipping Dimensions (hwd / in.) 11.22 x 5.39 x 20.35 Shipping Weight (lbs.) 8.44 Shipping Weight (kg) 3.83 Unit Dimensions (hwd / in.) 1.640 x 18.900 x 8.450 Unit Dimensions (hwd / cm) 4.17 x 48.01 x 21.46 Unit Weight (lbs.) 6.570 Unit Weight (kg) 2.98 STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
SRFAN1UTEMP 价格&库存
很抱歉,暂时无法提供与“SRFAN1UTEMP”相匹配的价格&库存,您可以联系我们找货
SRFAN1UTEMP
    • 1+2605.132661+314.53437
    • 10+2387.4710510+288.25469
    库存:7
