SRPDU4PHDBRKT
SRPDU4PHDBRKT
    TRIPPLITE
    支架 支架
SRPDU4PHDBRKT 数据手册
SmartRack Vertical PDU Installation Bracket for Server Racks MODEL NUMBER: SRPDU4PHDBRKT Highlights ● Compatible with rack enclosures and open frame racks (with included adapters) ● Upper and lower brackets support up to three vertical (0U) PDUs or cable managers ● Supports PDU mounting with toolless button mounts ● Sturdy steel construction provides a secure mounting surface ● Mounting hardware is included Package Includes Supports mounting of up to three vertical PDUs or cable managers in a rack enclosure or on a 2-post or 4post open frame rack. Features Bracket Enhances Functionality of Enclosures and Open Frame Racks The SRPDU4PHDBRKT allows the addition of up to three vertical PDUs or cable managers to a Tripp Lite rack enclosure or open frame rack, helping you avoid the need to invest in a larger rack configuration. Upper and lower brackets attach to the frame of a standard or heavy-duty rack enclosure using the included screws and cage nuts. Included adapter plates allow connection to mounting rails in 2-post or 4post open frame racks. Supports Toolless Mounting of Up to 3 Vertical PDUs or Cable Managers Up to three vertical PDUs or cable management accessories can be mounted to the SRPDU4PHDBRKT brackets. Keyhole slots support toolless button mounting. The brackets also have equipment mounting holes for attaching PDUs and cable managers with fasteners. Specifications OVERVIEW UPC Code 037332252722 Accessory Type Mounting Accessories; Mounting Bracket Accessory Class Rack Accessories PHYSICAL Material of Construction Steel Unit Dimensions (hwd / in.) 2.360 x 12.000 x 3.346 WARRANTY & SUPPORT 1/2 ● Vertical PDU Installation Bracket for Server Racks ● (2) Mounting brackets ● (2) Adapter plates for open frame racks ● (4) M6 screws ● (4) Cage nuts ● (4) 8-32 flange nuts ● Owner's manual Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRPDU4PHDBRKT 价格&库存
很抱歉,暂时无法提供与“SRPDU4PHDBRKT”相匹配的价格&库存,您可以联系我们找货
