SRWB18410X2STR
SRWB18410X2STR
    TRIPPLITE
    电缆走道 用于 线缆,导线
SRWB18410X2STR 数据手册
Wire Mesh Cable Tray - 450 x 100 x 1500 mm (18 in. x 4 in. x 5 ft.), 2-Pack MODEL NUMBER: SRWB18410X2STR Highlights ● 2 spans of wire basket in 5 ft. lengths with included hardware to create a 10 ft. span ● Cuts cable clutter by routing bundles along the wall, floor or ceiling in your data center ● Smooth, rounded wire construction prevents cable fraying due to sharp ends ● Large mesh size allows convenient cable routing through the open spaces ● Ideal for organizing cable in data centers, network closets and industrial areas Applications Neatly bundle network or other copper cables along the wall, floor or ceiling of your data center Provides wall-, floor- or ceiling-based copper cable routing, allowing organized category cable bundling within your data center. System Requirements Features Package Includes Eliminate Cable Stress by Organizing Copper Cabling Through Your Data CenterThis SmartRack® Wire Mesh Cable Tray is easy to install along the wall, floor or ceiling of your data center. The SRWB18410X2STR is a straight section measuring 1,500 millimeters long, but you can cut it with sideaction bolt cutters to fit your custom specifications. It also measures 450 millimeters wide and 100 millimeters high to allow you to neatly bundle network and audio/video cables. Constructed from High-Strength Steel Wire Built to Last in Busy EnvironmentsThe black powdercoated wire is smooth and rounded, which not only protects cable installers and IT personnel from cutting their hands, but also prevents cables from fraying along sharp edges. The rounded wire also prohibits debris from building up on it in dusty network closets and industrial spaces. Large mesh openings allow you to route cables through the spaces if needed. Designed to Give You Great Flexibility in Installation, Transportation and StorageThe SRWB18410X2STR is ideal for data centers, network closets and some industrial areas in a wide variety of applications, including office buildings, shopping centers, schools, hotels, hospitals, restaurants and transportation centers. Each tray can be stacked with another for multi-level installations to save space during transportation or storage. Specifications OVERVIEW UPC Code 037332261243 Product Type Cable Tray Accessory Type Cable Management Accessories Cable Management System Component Type Cable Tray 1/2 SRWB Coupler ● (2) Spans of wire mesh cable tray, 5 ft. ● (4) Toolless Couplers ● Installation guide PHYSICAL Color Black Cable Jacket Color Black Unit Dimensions (hwd / in.) 4.330 x 18.500 x 61.020 Unit Dimensions (hwd / cm) 11.000 x 46.990 x 150.000 Unit Weight (lbs.) 22.300 Unit Weight (kg) 10.12 STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 126.1-09; NFPA 70 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRWB18410X2STR 价格&库存
很抱歉,暂时无法提供与“SRWB18410X2STR”相匹配的价格&库存,您可以联系我们找货
