SRWB6210STR10
SRWB6210STR10
    TRIPPLITE
    WIRE MESH CABLE TRAY - 150 X 50
SRWB6210STR10 数据手册
Wire Mesh Cable Tray - 150 x 50 x 3000 mm (6 in. x 2 in. x 10 ft.), 10 Pack MODEL NUMBER: SRWB6210STR10 Highlights ● Package includes 10 total spans of wire mesh cable tray ● Cuts cable clutter by routing bundles along the wall, floor or ceiling in your data center ● Smooth, rounded wire construction prevents cable fraying due to sharp ends ● Large mesh size allows convenient cable routing through the open spaces ● Ideal for organizing cable in data centers, network closets and industrial areas Applications ● Provides wall-, floor- or ceiling-based copper cable routing, allowing organized category cable bundling within your data center. Neatly bundle network or other copper cables along the wall, floor or ceiling of your data center System Requirements ● Wire basket coupling and supporting equipment Features Eliminate Cable Stress by Organizing Copper Cabling Through Your Data CenterThis SmartRack® Wire Mesh Cable Tray is easy to install along the wall, floor or ceiling of your data center. The SRWB6210STR10 is a straight section measuring 3000 millimeters long, but you can cut it with sideaction bolt cutters to fit your custom specifications. It also measures 150 millimeters wide and 50 millimeters high to let you neatly bundle network and audio/video cables. Constructed from High-Strength Steel Wire Built to Last in Busy EnvironmentsThe black powdercoated wire is smooth and rounded, which not only protects cable installers and IT personnel from cutting their hands, but also prevents cables from fraying along sharp edges. The rounded wire also prohibits debris from building up on it in dusty network closets and industrial spaces. Large mesh openings allow you to route cables through the spaces if needed. Designed to Give You Great Flexibility in Installation, Transportation and StorageThe SRWB6210STR10 is ideal for data centers, network closets and some industrial areas in a wide variety of applications, including office buildings, shopping centers, schools, hotels, hospitals, restaurants and transportation centers. Each tray can be stacked with another to save space during transportation or storage. Specifications OVERVIEW UPC Code 037332262127 Product Type Cable Tray Accessory Type Cable Management Accessories Cable Management System Component Type Cable Tray 1/2 Package Includes ● (10) Wire Mesh Cable Trays 150 x 50 x 3000 mm ● Installation guide PHYSICAL Color Black Cable Jacket Color Black Unit Dimensions (hwd / in.) 2.360 x 6.690 x 118.110 Unit Dimensions (hwd / cm) 5.990 x 16.990 x 300.00 Unit Weight (lbs.) 9.790 Unit Weight (kg) 4.44 STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 126.1-09; NFPA 70 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SRWB6210STR10 价格&库存
很抱歉,暂时无法提供与“SRWB6210STR10”相匹配的价格&库存,您可以联系我们找货
