1000 Eaton Boulevard
Cleveland, OH 44122
United States
Wire Mesh Cable Tray - 150 x 50 x 1500 mm (6 in.
x 2 in. x 5 ft.), 2-Pack
MODEL NUMBER: SRWB6210X2STR
Highlights
2 spans of wire basket in 5 ft.
lengths with included hardware
to create a 10 ft. span
Cuts cable clutter by routing
bundles along the wall, floor or
ceiling in your data center
Smooth, rounded wire
construction prevents cable
fraying due to sharp ends
Large mesh size allows
convenient cable routing
through the open spaces
Ideal for organizing cable in data
centers, network closets and
industrial areas
Applications
Neatly bundle network or other
copper cables along the wall, floor
or ceiling of your data center
Provides wall-, floor- or ceiling-based copper cable routing, allowing organized category cable bundling
within your data center.
System Requirements
Features
Package Includes
Eliminate Cable Stress by Organizing Copper Cabling Through Your Data CenterThis SmartRack®
Wire Mesh Cable Tray is easy to install along the wall, floor or ceiling of your data center. The
SRWB6210X2STR is a straight section measuring 1,500 millimeters long, but you can cut it with sideaction bolt cutters to fit your custom specifications. It also measures 150 millimeters wide and 50
millimeters high to let you neatly bundle network and audio/video cables.
Constructed from High-Strength Steel Wire Built to Last in Busy EnvironmentsThe black powdercoated wire is smooth and rounded, which not only protects cable installers and IT personnel from cutting
their hands, but also prevents cables from fraying along sharp edges. The rounded wire also prohibits
debris from building up on it in dusty network closets and industrial spaces. Large mesh openings allow
you to route cables through the spaces if needed.
Designed to Give You Great Flexibility in Installation, Transportation and StorageThe
SRWB6210X2STR is ideal for data centers, network closets and some industrial areas in a wide variety of
applications, including office buildings, shopping centers, schools, hotels, hospitals, restaurants and
transportation centers. Each tray can be stacked with another to save space during transportation or
storage.
Specifications
OVERVIEW
UPC Code
037332260918
Product Type
Cable Tray
Accessory Type
Cable Management Accessories
Cable Management System
Component Type
Cable Tray
1/2
SRWB coupler
(2) Spans of wire mesh cable
tray, 5 ft.
(4) Toolless couplers
Installation guide
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Cable Jacket Color
Black
Unit Dimensions (hwd / in.)
2.360 x 6.690 x 61.020
Unit Dimensions (hwd / cm)
5.990 x 16.990 x 150.00
Unit Weight (lbs.)
9.790
Unit Weight (kg)
4.44
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SRWB6210X2STR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1461.828271+189.26304
- 10+1296.8561310+167.90408
- 25+1263.6122025+163.59999
