Large Arc Buffer Link Span Kit for Wire Mesh
Cable Trays (4 in. tall)
MODEL NUMBER: SRWBARCBFFL4
Highlights
Securely and safely connects
wire mesh cable trays along a
ceiling, floor or wall
Allows you more flexibility in
routing custom cable
management intersections
Compatible with wire mesh
cable trays measuring 4 in. tall
Includes 4 couplers for
immediate installation in your
data center
Applications
Organize a wire mesh cable tray
system with intersecting
sections along the wall, floor or
ceiling of your data center
System Requirements
Provides structural support and creates a radius for connecting an intersection in your custom-designed
wire mesh runway.
Features
Compatible with 4-inch-tall wire
mesh cable trays, such as Tripp
SRWB6410STR,
SRWB12410STR and
SRWB18410STR
Package Includes
Arc Buffer Bracket Helps You Create Custom Cable Management Schemes
This SmartRack® arc buffer creates a secure connection point between two intersecting sections of wire
mesh cable tray in your server room or data center. This allows you to create a radius for 90-degree
intersections and shape the direction of cabling to your liking. The black powder-coated metal plate adds a
radius that further strengthens and supports the bundled cables, allowing for more voluminous and
comprehensive runs. Four couplers are included for quick installation. The SRWBARCBFFL4 is designed
for wire mesh cable trays four inches in height, such as Tripp Lite’s SRWB6410STR, SRWB12410STR
and SRWB18410STR.
Specifications
OVERVIEW
UPC Code
037332247988
Product Type
Elbow
Accessory Type
Cable Management Accessories
Cable Management System
Component Type
Elbow
PHYSICAL
Color
Black
Cable Jacket Color
Black
Shipping Dimensions (hwd / in.)
4.13 x 18.90 x 10.63
Shipping Weight (kg)
0.74
1/2
Arc buffer
(4) SRWBUNVCPLR couplers
Installation guide
Unit Dimensions (hwd / in.)
3.970 x 11.380 x 11.380
Unit Dimensions (hwd / cm)
10.0838 x 28.9052 x 28.9052
Unit Weight (lbs.)
0.500
Unit Weight (kg)
0.23
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 126.1-09; NFPA 70
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“SRWBARCBFFL4”相匹配的价格&库存,您可以联系我们找货
