SU3000LCD2UHV
SU3000LCD2UHV
    TRIPPLITE
    UPS SMART ONLINE LCD RACKMOUNT
SU3000LCD2UHV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 208/240V 3000VA 2.7kW Double-Conversion UPS - 8 Outlets, Extended Run, Card Slot, LCD, USB, DB9, 2U Highlights ● Offers network-grade protection against power failures and voltage fluctuations ● Zero transfer time between online and battery modes for uninterrupted operation ● Optional external battery packs provide additional runtime for applications requiring it ● Optional WEBCARDLXE network interface required to use Auto Probe feature ● ENERGY STAR-certified to save electricity, lower costs, and protect the environment MODEL NUMBER: SU3000LCD2UHV Applications On-line double-conversion UPS provides pure sine wave AC output to server and network equipment in data centers and computer rooms. ● Deliver perfectly regulated sine wave output to mission-critical equipment ● Protect connected components from dangerous surges, spikes and line noise ● Keep equipment operational through power failures ● Allow time to save data and safely shut down components in case of a prolonged blackout Features Double-Conversion UPS Protects Equipment against Damage, Downtime and Data Loss This 200/208/220/230/240V 50/60 Hz UPS system maintains perfect output by converting AC input to DC, then reconverting UPS output to fully regulated sine wave AC with +/-2% voltage regulation in online and battery modes. Featuring a 2700W capacity, high 0.9 power factor, 570 joules of surge suppression, true on-line operation with pure sine wave output and zero transfer time in on-line double-conversion mode, the SmartOnline® SU3000LCD2UHV double-conversion UPS provides the highest level of AC power protection and battery backup for critical network closet, computer room and data center equipment. Set Power Strategies to Reflect Your Protection Priorities Pick your power strategy, from precise power for sensitive systems to the highest possible electrical efficiency, while ensuring 100% uptime. Choose from five selectable strategies: Max Efficiency, Max Quality, Frequency Regulation, Frequency Conversion and Auto Adaptive, which automatically offers increased efficiency when power conditions are good and enhanced power quality when power conditions are poor. Individually Controllable Load Banks Let You Access and Control Outlets Remotely Four NEMA 6-15/20R outlets are split evenly into two switchable load banks, allowing you to reboot select components or shed loads remotely. In addition to those four outlets, this UPS provides two more NEMA 6-15/20R outlets in their own unswitched bank, as well as two NEMA L6-20R outlet dongles, for powering critical components. Reliable, Expandable Battery Backup Keeps You Operational Through Power Outages The field-replaceable, hot-swappable internal battery provides 13.5 minutes of support at half load (1350W) and five minutes at full load (2700W), keeping protected equipment operational through power failures. For mission-critical applications demanding scalable extended runtime, the UPS supports “smart” external battery packs, such as BP72V18-2US (sold separately). Both the internal and external batteries are automatically sensed and configured during replacement to offer accurate runtime-remaining and battery age notifications during outages. The intelligent battery management system with temperaturecompensated charging extends battery life. Automatic Bypass Maintains Utility Output During Fault Conditions Auto-bypass mode keeps connected equipment powered and operational, even during UPS fault 1/7 Package Includes ● SU3000LCD2UHV SmartOnline Double-Conversion UPS ● USB cable ● RS-232 cable ● EPO cable ● 4-post rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States conditions. ENERGY STAR-Certified to Help You Save Money and Protect the Environment By meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save money and energy. A power-saving Economy mode setting option offers enhanced efficiency and reduced BTU output when utility power is already high quality. Automatically Turns Back On After Power Is Restored Battery-independent restart ensures automatic UPS power-up without user interaction after lengthy power outages, even when batteries are expired and require replacement. Intuitive Front-Panel Interface for Convenient UPS Operation and Monitoring The front-panel LCD screen reports UPS operating mode, detailed UPS status and site-power information, as well as a variety of advanced UPS setup and configuration options. LEDs indicate AC input/output, battery and fault status. Advanced Communications Ports Allow for Automatic Saves and Shutdowns RS-232 and HID-compliant USB ports connect to a computer running free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. An EPO port connects the UPS to a contact closure switch to enable emergency inverter shutdown. Cables are included. Optional WEBCARDLXE Network Interface Offers 24/7 Access The SU3000LCD2UHV includes a slot for an optional Java-free HTML5-based WEBCARDLXE (sold separately) that enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Automated alerts help prevent accidental overloads, power loss and downtime. WEBCARDLXE 15.5.2 or later is required to use the Auto Probe feature, which can prevent costly service calls by automatically rebooting non-responsive network devices. Versatile Installation Options Hardware is included for mounting the UPS system in 2U of space in an EIA-standard 19-inch 4-post rack. Use the optional 2POSTRMKITWM (sold separately) for 2-post rack mounting or the optional 2-9USTAND (sold separately) for mounting in an upright tower position. The 10-ft. (3.05 m) power cord with NEMA L620P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332180742 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 14.97A Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC UPS Input Connection Type L6-20P UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 208/240V 20A 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States OUTPUT Output Capacity (VA) 3000 Output Capacity (kVA) 3 Output Capacity (Watts) 2700 Output Capacity (kW) 2.7 Output Capacity Details DE-RATING INFORMATION: Max output in Frequency Conversion mode is reduced to 1890 watts for 208/220/230/240V output voltages; Max output is reduced to 2160W at 200V output voltage in all operating modes OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% for 3 minutes, 150% for 30 seconds and >150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits). Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details Nominal output voltage is user configured on first power-on Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Output capacity de-rates by 30% during frequency conversion operation Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable outlet load banks (2 NEMA 6-15/20R outlets per bank) Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles (6) 6-15/20R; (2) L6-20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (2700W) Runtime Half Load (min.) 13.5 min. (1350W) Expandable Runtime Yes External Battery Pack Compatibility  BP72V15-2U  (limit 1); BP72V28RT-3U (multi-pack compatible);  BP72V18-2US  (multi-pack compatible) DC System Voltage (VDC) 72 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Recharge Rate (Included Batteries) 3.0 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC72S  Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 288 Undervoltage Correction 2% output voltage regulation during undervoltages to 160V (100% load), 130V (70% load), 100V (30% load) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Interactive front-panel LCD interface reports UPS operating mode, detailed UPS status and site-power information; LCD interface also enables a variety of advanced UPS setup and configuration options Switches 5 front panel switches: On/Off, Up, Down and Escape Alarm Cancel Operation Power-fail alarm can be silenced by following on-screen prompts Audible Alarm Audible alarm indicates power failure, low battery, overload and fault LED Indicators 4 front panel LEDs: AC input (green), AC output (green), Battery (yellow), Fault (red) SURGE / NOISE SUPPRESSION UPS Dataline Suppression Details Single line dialup / network dataline protection included EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 570 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description 4 post installation accessories included Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 71.12 Minimum Required Rack Depth (inches) 28 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth with External Battery Pack (cm) 77 Minimum Required Rack Depth with External Battery Pack (in.) 30.25 Minimum Required Rack Depth without External Battery Pack (cm) 74 Minimum Required Rack Depth without External Battery Pack (in.) 29.25 Primary UPS Depth (mm) 616 Primary UPS Height (mm) 88 Primary UPS Width (mm) 438 Shipping Dimensions (hwd / in.) 9.45 x 23.62 x 29.92 Shipping Dimensions (hwd / cm) 24.00 x 59.99 x 76.00 Shipping Weight (lbs.) 86.00 Shipping Weight (kg) 39.01 UPS Housing Material Metal UPS Power Module Dimensions (hwd, cm) 8.79 x 43.79 x 61.60 UPS Power Module Dimensions (hwd, in.) 3.46 x 17.24 x 24.25 UPS Power Module Weight (kg) 32.12 UPS Power Module Weight (lbs.) 70.81 Unit Dimensions (hwd / in.) 3.460 x 17.240 x 24.250 Unit Weight (lbs.) 70.8100 Unit Weight (kg) 32.12 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 5 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 933 AC Economy Mode BTU / Hr. (Full Load) 588 AC Mode Efficiency Rating (100% Load) >90% AC Economy Mode Efficiency Rating (100% Load) >95% Online Mode Heat Dissipation (BTU/Hr) @ Full Load 933 Battery Mode Heat Dissipation (BTU/Hr) @ Full Load 1399 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Audible Noise
SU3000LCD2UHV 价格&库存
很抱歉,暂时无法提供与“SU3000LCD2UHV”相匹配的价格&库存,您可以联系我们找货
