1000 Eaton Boulevard
Cleveland, OH 44122
United States
UPS Maintenance Bypass Panel for SUTX40K - 3
Breakers
MODEL NUMBER: SUT40KMBPX
Highlights
Isolates UPS from connected
loads for maintenance without
losing network availability
Maintenance bypass panel
mounts to wall next to UPS for
convenient access
125A 10 kAIC unit has three 4pole built-in circuit breakers
connected to heavy-duty
buswork
Secure Kirk-key interlock
system prevents unauthorized
access to power
Compatible with Tripp Lite’s
SUTX40K 3-phase UPS system
Applications
UPS bypass panel reroutes power to keep essential equipment operational while the UPS is inoperative
or under maintenance.
System Requirements
Features
UPS Maintenance Bypass Panel Keeps Equipment Powered During UPS MaintenanceThis wallmount three-breaker maintenance bypass panel is compatible with Tripp Lite’s SUTX40K 3-phase UPS
system. It allows you to reroute power around the UPS, providing an alternate path for electricity that
keeps the connected load operational while the UPS is offline for maintenance or repairs.
Features 3 Built-In Circuit Breakers to Isolate LoadsThree 4-pole circuit breakers – an AC input
breaker, a maintenance bypass breaker and a maintenance isolation breaker – are connected to heavyduty buswork and isolate the UPS system from its connected load with no loss of network availability. This
allows the load to remain continuously powered without costly downtime. A Kirk-key interlock system
enhances safety and security. Removable handles allow the panel’s trim cover to be removed for internal
access. The 125A unit has a kAIC rating of 10K.
Switching Between Normal and Bypass Modes Is EasyWhen a UPS needs maintenance, this UPS
bypass panel keeps power supplied to components via its mechanical interlock system by switching
power to the external bypass breaker. Simply unscrew the interlock switch, rotate the switch from the UPS
AC input breaker (SW1) to the bypass breaker (SW2), then turn on the bypass breaker and turn off the
UPS and isolation breaker (SW3) to perform UPS maintenance without service interruption.
Convenient Wall-Mount InstallationMade of galvanized steel, the service bypass panel has rear
mounting holes for installation on a smooth, solid wall (mounting hardware not included).
Specifications
OVERVIEW
UPC Code
037332241108
Accessory Type
Bypass Panel
Accessory Class
UPS Accessories
1/2
Bypass a compatible offline 3phase UPS system to continue
powering mission-critical
equipment without interruption
Tripp Lite SUTX40K 3-phase
UPS system
Package Includes
SUT40KMBPX UPS
SUTX40K - 3 Breakers
Installation and Operation
Manual
Cleveland, OH 44122
United States
INPUT
Nominal Input Voltage Description
400Y/230 VAC 3 phase, 4 wire (3P+N+E)
OUTPUT
Output Capacity Details
125A maximum
PHYSICAL
Form Factors Supported
Wallmount
Shipping Dimensions (hwd / in.)
22.00 x 25.00 x 10.00
Shipping Weight (kg)
13.61
Unit Dimensions (hwd / in.)
17.500 x 20.000 x 4.600
Unit Dimensions (hwd / cm)
44.45 x 50.8 x 11.68
Unit Weight (lbs.)
Unit Weight (kg)
9.07
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“SUT40KMBPX”相匹配的价格&库存,您可以联系我们找货
