1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline SV Series 40kVA Small-Frame
Modular Scalable 3-Phase On-Line DoubleConversion 208/120V 50/60 Hz UPS System, 3
Battery Modules
MODEL NUMBER: SV40KS2P3B
Highlights
Scalable capacity up to 60kVA
(or 40kVA with N+1 fault
tolerance)
Economy mode option helps
reduce operating and cooling
costs
Pre-installed WEBCARDLX
network interface for 24/7
remote access
DSP/IGBT technology and 1%
output voltage regulation
Includes 3 internal battery
modules
For extended runtimes beyond
those provided by internal
battery modules, please review
the suffix "0B" SV models
without internal battery modules,
which offer different external
battery pack options.
Package Includes
3-phase 40kVA UPS system offers network-grade power protection in a highly configurable, modular and
scalable small-chassis rack-width frame. Included battery modules can support a half load up to 15
minutes.
Description
The SV40KS2P3B SmartOnline® SV Series 40kVA Small-Frame 3-Phase On-Line Double-Conversion
UPS System delivers true scalability and offers the highest level of secure, uninterrupted power
protection. Featuring a modular, scalable design with high-efficiency voltage and frequency independent
(VFI) operation, this on-line UPS system with a high 0.9 power factor is ideal for protecting a variety of
critical IT systems.
The SV40KS2P3B includes pre-installed input, bypass and output breakers, as well as a static transfer
switch (STS), two 20kVA SV20PM power modules and three SVBM battery modules. Space is included
for one additional user-installable SV20PM power module.
The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS
status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or
SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network.
With up to 92% efficiency in standard mode and up to 98% efficiency in optional economy mode, this
40kVA UPS system helps you reduce operating and cooling costs. Automatic and manual bypass options
keep connected equipment operational during routine maintenance or critical power module failure. Frontpanel display offers full UPS condition and status reporting.
Features
40kVA 36kW 3-Phase Small-Chassis UPS SystemSupports 208/120V or 220/127V AC 50/60Hz Wye 4wire plus Earth hardwire input and output wiringDual hardwire input design enables operation from up to 2
power sourcesNetwork-grade sine-wave AC output with 1% output voltage regulation and less than 2%
output total harmonic distortionTested to UL 1778 (U.S.), CSA (Canada) and NOM (Mexico)
standardsHigh 0.9 power factor offers higher kW output than lower-rated competing legacy designs
Pre-Installed WEBCARDLX Network InterfaceAllows full remote access for power monitoring,
configuration, control and email notifications via secure web browser, SNMP, telnet or SSHSupports
10/100 Mbps auto-sensing for communication with an Ethernet networkOptional EnviroSense2 sensors
(sold separately) enable site monitoring of temperature, humidity and contact-closure statusNo Java
required
1/6
SV40KS2P3B SmartOnline SV
Series 40kVA Small-Frame 3Phase On-Line DoubleConversion UPS System
network interface
(2) SV20PM 20kVA power
modules (shipped separately)
(3) SVBM battery modules
Owner’s manual
Cleveland, OH 44122
United States
Modular, Scalable Design for Maximum FlexibilityModular configuration with hot-swappable power and
battery modules enables easy, fast maintenance with zero downtimeOpen slot for 1 additional 20kVA
SV20PM power module accommodates increased capacity up to 60kVA (or 40kVA with N+1 fault
tolerance)
Optional Economy ModeUp to 98% efficiency in optional economy mode to lower operating and cooling
costs
Wide Input/Narrow Output Voltage Operating RangeEnables full continuous online operation during
brownouts as low as 121V and overvoltages up to 253VRegulates output voltage within 1% of the
selected nominal output voltage in on-line double-conversion mode
Advanced IGBT Inverter with Digital Signal Processor (DSP) TechnologyProvides for less than 3%
input total harmonic distortion (THDi) to support 1:1 generator sizing and prevent the need to oversize
generator systems relative to UPS capacity
Automatic and Manual Bypass OptionsKeep connected equipment operational during routine
Specifications
OVERVIEW
UPC Code
037332236456
UPS Type
On-Line
INPUT
Input Phase
3-Phase
Rated input current (Maximum Load)
SV40KS2P3B 40kVA Configuration: 120A; Maximum 60kVA Configuration: 180A; 313.7A maximum inrush current
Nominal Input Voltage(s) Supported
120/208V 3-PH Wye; 127/220V 3-PH Wye
Nominal Input Voltage Description
Set of two hardwire input connections enables 3-Phase Wye, 4 wire (3P, N, E) inputs from two separate power
sources
UPS Input Connection Type
Hardwire
Input Circuit Breakers
MAIN and ALTERNATE AC inputs are each protected by 250A 3 pole magnetic breakers
Input Frequency
40 to 70Hz (online mode); 50/60Hz Auto-selectable
Power Factor (Input)
Greater than 0.99 (full load)
THDi
Less than 3% (full linear load)
OUTPUT
Output Capacity (VA)
40000
Output Capacity (kVA)
40
Output Capacity (Watts)
36000
Output Capacity (kW)
36
Output Capacity Details
OVERLOAD CAPABILITY: Supports 105-110% load for 1 hour, 111-125% load for 10 minutes, 126-150% for 1
minute and Over 150% for 200ms before switching to Bypass; Online operation resumes when load is reduced to
100% or less
2/6
Cleveland, OH 44122
United States
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
Output THD full resistive load:
很抱歉,暂时无法提供与“SV40KS2P3B”相匹配的价格&库存,您可以联系我们找货
