TLP104USB
TLP104USB
    TRIPPLITE
    1-OUTLET SURGE PROTECTOR WITH 2
TLP104USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1-Outlet Surge Protector with 2 USB Ports (2.1A Shared) - 4 ft. Cord, 5-15P Plug, 450 Joules, Black Highlights ● Single NEMA 5-15R outlet designed to accommodate a bulky transformer ● 450 joules protect your valuable electronics against dangerous surges and spikes ● 2 USB ports share 2.1A for fast charging of phones, tablets and other mobile devices ● Right-angle NEMA 5-15P plug with 4 ft. cord allows connection in tight spaces ● Green LED assures you at a glance that your valuable electronics are protected MODEL NUMBER: TLP104USB Applications ● Protect a computer, router or other valuable electronics against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges ● Charge a smartphone and tablet without taking up available AC outlets Single-outlet surge protector with USB charging safeguards your home/office electronics against dangerous surges, spikes and line noise. Features Surge Protector with USB Charging Safeguards Your Sensitive Electronics Ideal for your home or office workstation or home theater, this Protect It!® single-outlet surge protector features a surge suppression rating of 450 joules to defend your sensitive electronic components against even the strongest power surges and spikes. NEMA 5-15R Outlet Accepts a Wide Range of Electronic Devices The NEMA 5-15R outlet is set apart on top of the surge protector to accept a bulky transformer without blocking the USB ports. Plug your PC, printer, wireless router, game console, television, sound system or other home/office device into the outlet for protection against dangerous surges, spikes and line noise. 2 USB Ports Share 2.1 Amps of Charging Power Two USB-A ports are available for charging your smartphone, tablet or other USB mobile devices. They share 2.1A for charging multiple devices at the same time. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Versatile Surge Protector Provides Multiple Installation Options This surge protector with four-foot cord and space-saving right-angle NEMA 5-15P plug allows you flexibility in placing the unit behind furniture or other tight places. Specifications 1/4 Package Includes ● TLP104USB 1-Outlet Surge Protector, Black ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332258670 Product Type Surge Protector Charging Form Factor Strip Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 16 gauge Input Cord Gauge (AWG) 16 Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Details SPT-2-B Input Cord Length (ft.) 4 Right-Angle Plug No Input Cord Length (m) 1.22 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (1) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable illuminated combo switch / circuit breaker Transformer Accommodation (1) Yes Outlet Orientation Single row of 1 outlet Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status CHARGING Number of Charging Ports 2 Total Charging Watts 10.5 Charging Method USB 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Port Type USB A (FEMALE) Charging Ports / Amps (2) 2.1A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 450 AC Suppression Response Time < 1 ns UL1449 Let Through Rating L-N, 800 EMI / RFI Filtering Yes Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Housing Color Black Mounting Holes or Slots Yes Receptacle Color Black Shipping Dimensions (hwd / in.) 7.10 x 4.10 x 1.50 Shipping Dimensions (hwd / cm) 18.03 x 10.41 x 3.81 Shipping Weight (lbs.) 0.00 Shipping Weight (kg) 0.00 Unit Dimensions (hwd / in.) 5.400 x 1.600 x 1.000 Unit Dimensions (hwd / cm) 2.1 X .63 X .39 Unit Weight (lbs.) 0.60 Unit Weight (kg) 0.27 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications CAN/CSA-C22.2 No. 21 (Canada); CAN/CSA-C22.2 No. 269.3 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 497A; UL 1363; UL 817; UL Listed Product Compliance FCC Part 68; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $1,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP104USB 价格&库存
很抱歉,暂时无法提供与“TLP104USB”相匹配的价格&库存,您可以联系我们找货
