TLP1G
TLP1G
    TRIPPLITE
    1-OUTLET SURGE PROTECTOR - GERMA
TLP1G 数据手册
1-Outlet Surge Protector - German Type F Schuko Outlet, 220-250V AC, 16A, Direct Plug, Schuko Plug, White Highlights ● German Schuko outlet distributes power to an appliance, tool or other device ● Plugs directly into the wall (no cord required) for easy installation in tight spaces ● 250 joules protect your valuable electronics against dangerous surges and spikes ● 16A circuit breaker shuts down outlet for safety in case of overload MODEL NUMBER: TLP1G Applications ● Protect a computer or peripheral against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges 1-outlet surge protector safeguards a home/office electronic device against dangerous surges, spikes and line noise. Package Includes Features ● 1-Outlet Surge Protector Safeguards Your Sensitive Electronics Against Power FluctuationsIdeal for your home or office workstation, this Protect It!® single-outlet surge protector features a surge suppression rating of 250 joules and provides protection in line-to-neutral (L-N) mode to defend your sensitive electronic components against power surges and spikes. Designed for Quick, Easy Connection in Tight Spaces Compatible with standard electrical equipment, this surge protector plugs directly into a Schuko wall outlet (no cord required), so you can install it behind furniture placed flush against the wall. It features one Schuko outlet and a durable white plastic housing. It is ideal for powering almost anything with a compatible plug, including computers and mobile devices to appliances and power tools. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Premium Safety Features for Protecting Your Valuable EquipmentA green LED confirms that your connected equipment is protected. In the event of an overload, a 16-amp circuit breaker immediately shuts down the surge protector to prevent equipment damage. Specifications OVERVIEW UPC Code 037332251640 1/3 TLP1G 1-Outlet Direct-Plug Surge Protector, German Type F Schuko Outlet, White INPUT Nominal Input Voltage(s) Supported 230V AC Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-250 Input Plug Type German Input Cord Length (ft.) 0 Right-Angle Plug No Input Cord Length (m) 0.00 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles Schuko Type F Circuit Breaker (amps) 16 Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 250 Protection Modes Includes full normal mode (H-N) Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color White Housing Color White Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 4.20 x 4.30 x 2.90 2/3 Shipping Dimensions (hwd / cm) 10.67 x 10.92 x 7.37 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 Unit Dimensions (hwd / in.) 2.100 x 2.700 x 2.900 Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
TLP1G 价格&库存
很抱歉,暂时无法提供与“TLP1G”相匹配的价格&库存,您可以联系我们找货
