TLP648USBC
TLP648USBC
    TRIPPLITE
    6-OUTLET SURGE PROTECTOR W/2 USB
TLP648USBC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-Outlet Surge Protector w/2 USB-A (4.8A Shared) & 1 USB-C (3A) - 8 ft. (2.43 m) Cord, 1080 Joules, Desk Clamp Highlights ● 6 NEMA 5-15R outlets distribute AC power to connected home/office equipment ● 1080 joules protect your valuable electronics against dangerous surges and spikes ● 2 USB-A/1 USB-C ports for fast charging of phones, tablets and other mobile devices ● 8-ft. (2.43 m) pivoting power cord with NEMA 5-15P plug easily adjusts to nearby wall outlets ● Spring-loaded clamp attaches to flat surface up to 2.5 in. thick for use anywhere MODEL NUMBER: TLP648USBC Applications 6-outlet desk-clamp surge protector safeguards your home/office electronics against dangerous surges, spikes and line noise. Features 6-Outlet Surge Protector with USB Safeguards Your Sensitive ElectronicsIdeal for your home or office workstation, this Protect It!® 6-outlet surge protector features a surge protection rating of 1080 joules to defend your sensitive electronic components against even the strongest power surges and spikes. Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP648USBC protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/H-G). Spring-Loaded Desk Clamp Protects Equipment at Any WorkstationThis portable surge protector features a spring-loaded clamp that attaches to any flat, smooth surface up to 2.5 inches thick, so you can take it with you to the office, dorm, conference room, hotel or anywhere else you need to plug in your electronic devices. The eight-foot power cord with NEMA 5-15P plug pivots 90 degrees to accommodate installation to a horizontal or vertical surface. NEMA 5-15R Outlets Accept a Wide Range of Electronic DevicesPlug your computer, printer, wireless router, desk lamp or other home/office electronics into six NEMA 5-15R outlets to protect them against dangerous surges, spikes and line noise. 3 USB Ports for Charging Mobile DevicesThis surge protector with 3 USB ports is ideal for keeping your devices at full capacity. Two USB-A ports 2.4 amps each for charging your smartphone, tablet and other USB mobile devices, which are also protected from the damaging effects of surges, spikes and line interference. In addition to the dual USB-A ports, a 3-amp USB-C port charges devices quickly and safely. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Includes the Latest Safety FeaturesThe on/off switch provides one-touch control over connected 1/4 ● Protect computers, peripherals, home theater equipment and other valuable electronics against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges ● Charge smartphones, tablets or other USB devices via USB ports Package Includes ● TLP648USBC Protect It! 6Outlet Surge Protector with Desk Clamp ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States equipment. Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required. A green LED confirms your connected equipment is protected. Specifications OVERVIEW UPC Code 037332231130 Product Type Surge Protector Charging Form Factor Strip Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge Type 14 gauge Input Cord Length Details 8 ft cord Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 8 Right-Angle Plug No Input Cord Length (m) 2.44 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes CHARGING Number of Charging Ports 3 Total Charging Watts 27 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (1) 3A; (2) 2.4A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1080 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500, 500, 600 EMI / RFI Filtering Yes Immunity Conforms to IEE 587/ANSI C62.41 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Gray Mounting Holes or Slots No Receptacle Color Gray Shipping Dimensions (hwd / in.) 5.43 x 4.72 x 6.73 Shipping Weight (kg) 0.88 Unit Dimensions (hwd / in.) 5.200 x 2.700 x 5.300 Unit Dimensions (hwd / cm) 13.21 x 6.86 x 13.46 Unit Weight (lbs.) 1.72 Unit Weight (kg) 0.78 Input Cord Color Gray FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); NOM (Mexico); UL 1449; UL 1363 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $50,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP648USBC 价格&库存
很抱歉,暂时无法提供与“TLP648USBC”相匹配的价格&库存,您可以联系我们找货
