TLP615B
TLP615B
    TRIPPLITE
    SURGE PROTECTOR POWER STRIP 15 F
TLP615B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 6-Outlet Surge Protector, 15 ft. Cord, 790 Joules, Black Housing MODEL NUMBER: TLP615B Highlights ● 6 NEMA 5-15R outlets, including one for bulky transformers ● Surge suppression rating of 790 joules ● Filters out threatening EMI/RFI line noise ● 15A resettable circuit breaker prevents dangerous overloads ● 15 ft. AC power cord reaches distant outlets Package Includes Safeguard your workstation or home electronics against surges, spikes and line noise. Ideal for protecting your computer, printer, scanner, external hard drive and other sensitive electronics. Description Perfect for your home or office workstation, the TLP615B Protect It!® 6-Outlet Surge Protector features a surge suppression rating of 790 joules to defend your sensitive electronic components against strong surges and spikes. The TLP615B includes full normal mode (H-N) and common mode (N-G/H-G) line surge suppression, as well as technology that filters out disruptive EMI/RFI line noise, preventing interference from disrupting your electronics and inflicting damage or data loss. Your computer and peripherals plug into six NEMA 5-15R outlets, including one designed to accept bulky transformers without blocking adjacent outlets. Integrated 15-amp circuit breaker protects all outlets against dangerous overloads. Lighted on/off switch provides one-touch control over connected equipment. Green LED indicates protection status. The 15-foot (4.6-meter) AC power cord with NEMA 5-15P plug allows the TLP615B to reach distant outlets, giving you flexibility in placing the power strip. Keyhole slots incorporated into the bottom panel provide convenient wall or desk mounting options for the black plastic housing. Features 790-Joule Surge Protection for Home or Office Electronics790-joule rating protects your computer, printer, scanner, external hard drive and other sensitive electronic components against even the strongest surges and spikesBacked by $20,000 Ultimate Lifetime Insurance for any connected components damaged by power surge (U.S., Canada and Puerto Rico only)Full normal mode (H-N) and common mode (N-G/H-G) line surge suppressionFilters out disruptive EMI/RFI line noise that can cause equipment damage or data lossExceeds IEEE 587 Category A and B surge suppression specifications 6 Outlets Accept Wide Range of Electronic Devices6 NEMA 5-15R AC outlets accept most computers and peripheralsSpecial end outlet designed for bulky transformers without blocking other outlets Premium Safety FeaturesLighted on/off switch provides one-touch control over connected equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is requiredGreen LED shows protection status at a glance Fits Effortlessly Into Your Workstation15 ft. AC power cord with NEMA 5-15P plug long enough to reach distant outletsKeyhole slots on bottom panel provide convenient wall or desk mounting optionsBlack plastic housing designed for long life 1/4 ● TLP615B Protect It! 6-Outlet Surge Protector, Black Housing ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Auto-ShutdownAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications OVERVIEW UPC Code 037332189820 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 35500 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable illuminated combo switch / circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position red illuminated on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status SURGE / NOISE SUPPRESSION 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Suppression Joule Rating 790 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500V EMI / RFI Filtering Up to 20 dB Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Housing Color Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between slots = 101 mm; Distance between slot height = 28 mm Outlets Measurement (Center to Center) 28.5mm Receptacle Color Black Shipping Dimensions (hwd / in.) 13.20 x 5.80 x 1.80 Shipping Dimensions (hwd / cm) 33.53 x 14.73 x 4.57 Shipping Weight (lbs.) 2.05 Shipping Weight (kg) 0.93 Unit Dimensions (hwd / in.) 10.800 x 1.850 x 1.230 Unit Dimensions (hwd / cm) 27.43 x 4.70 x 3.12 Unit Weight (lbs.) 1.60 Unit Weight (kg) 0.73 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $20,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP615B 价格&库存
很抱歉,暂时无法提供与“TLP615B”相匹配的价格&库存,您可以联系我们找货
