TLP64USBRA15
TLP64USBRA15
    TRIPPLITE
    6-OUTLET SURGE PROTECTOR WITH 4
TLP64USBRA15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-Outlet Surge Protector with 4 USB Ports (4.2A Shared) - 15 ft. (4.57 m) Cord, 5-15P Plug, 900 Joules, White Highlights ● 6 NEMA 5-15R outlets, including 2 designed to accommodate bulky transformers ● 900 joules protect your valuable electronics against dangerous surges and spikes ● 4 USB ports share 4.2A for fast charging of phones, tablets and other mobile devices ● 15-ft. (4.57 m) cord with rightangle NEMA 5-15P plug allows flexibility in placing devices ● Green LED reassures you at a glance that your valuable electronics are protected MODEL NUMBER: TLP64USBRA15 Applications ● Protect computers, peripherals, home theater equipment and other valuable electronics against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges ● Charge a smartphone and tablet without taking up available AC outlets 6-outlet surge protector with USB charging safeguards your home/office electronics against dangerous surges, spikes and line noise. Features 6-Outlet Surge Protector with USB Charging Safeguards Your Sensitive ElectronicsIdeal for your home or office workstation or home theater, this Protect It!® 6-outlet surge protector features a surge suppression rating of 900 joules to defend your sensitive electronic components against even the strongest power surges and spikes. NEMA 5-15R Outlets Accept a Wide Range of Electronic DevicesPlug your PC, printer, wireless router, game console, television, sound system or other home/office electronics into six NEMA 5-15R outlets to protect them against dangerous surges, spikes and line noise. Two outlets are set apart from the others to accept bulky transformers without blocking adjacent outlets. 4 USB Ports Share 4.2 Amps of Charging PowerFour USB-A ports are available for charging your smartphone, tablet and other USB mobile devices. They share 4.2A for charging multiple devices at the same time. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Premium Safety Features Protect Your Valuable EquipmentThe lighted on/off switch provides onetouch control over connected equipment. A 15A circuit breaker protects all outlets and automatically cuts power if the protection circuit is incapacitated, preventing equipment damage. A green LED confirms your connected equipment is protected. Versatile Surge Protector Provides Multiple Installation OptionsThis surge protector with 15-ft. (4.57 m) cord and space-saving right-angle NEMA 5-15P plug allows you flexibility in placing the unit away from a wall outlet or behind furniture. Keyhole slots incorporated into the bottom panel provide convenient wall or desk mounting options for the black plastic housing. 1/4 Package Includes ● TLP64USBRA15 6-Outlet Surge Protector, White ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332241238 Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 35500 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable illuminated combo switch / circuit breaker Transformer Accommodation (4) Yes Outlet Orientation Single row of 6 outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position red illuminated on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status CHARGING 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Number of Charging Ports 4 Total Charging Watts 21 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (4) 4.2A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 900 AC Suppression Response Time < 1 ns UL1449 Let Through Rating 800,800,800 EMI / RFI Filtering Yes Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Gray Housing Color Light Gray Mounting Holes or Slots Yes Receptacle Color Gray Shipping Dimensions (hwd / in.) 11.02 x 8.70 x 1.80 Shipping Weight (kg) 1.29 Unit Dimensions (hwd / in.) 9.450 x 3.580 x 1.450 Unit Dimensions (hwd / cm) 3.73 x 1.14 x .57 Unit Weight (lbs.) 2.10 Unit Weight (kg) 0.95 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 497A; UL 1363; UL Listed Product Compliance FCC Part 68; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $25,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP64USBRA15 价格&库存
很抱歉,暂时无法提供与“TLP64USBRA15”相匹配的价格&库存,您可以联系我们找货
