U024AB-006-WH
U024AB-006-WH
    TRIPPLITE
    USB 2.0 缆线 A 公型至 A 母型 6.00'(1.83m) 屏蔽
U024AB-006-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Safe-IT USB 2.0 Antibacterial Extension Cable (A M/F), USB 2.0, White, 6 ft. (1.83 m) MODEL NUMBER: U024AB-006-WH Highlights ● Supports USB 2.0 speeds up to 480 Mbps to ensure efficient data transfers ● Made with antibacterial material proven effective in inhibiting the growth of E. coli and staph ● Foil and braid shielding protects against EMI/RFI noise that can distort or destroy data ● Gold-plated connectors provide maximum conductivity and minimum data loss ● White jacket permits fast, easy identification in a crowded hub or computer Applications ● Connect a computer or laptop and a USB peripheral in a home or office network ● Extend an existing USB connection up to 6 ft. to more easily place a device ● Provide extra protection against bacteria to give cable installers and IT personnel peace of mind during installation USB cable with antibacterial material extends your existing USB connection by 6 ft. while helping to protect you from harmful bacteria. Features 6 ft. USB-A Extension Cable Transfers Important Data at USB 2.0 Speeds This USB cable (M/F) extends your current USB 2.0 cable connection by six feet. It connects your computer, laptop or other USB-A device to a keyboard, printer, external hard drive, modem or other peripheral. It transfers data at USB 2.0 speeds up to 480 Mbps for use with low-speed and high-speed devices, including multimedia applications. The cable is also backward compatible with earlier USB generations. Provides Extra Protection Against Certain Bacteria The molded connectors and PVC jacket are constructed using an antibacterial material that is effective in inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added protection makes this cable an ideal solution for medical facilities, schools, businesses, restaurants/kitchens and anywhere else that needs extra protection against bacteria. Premium Construction for Superior Performance Manufactured with twisted 28 AWG data lines and 24 AWG power lines, the U024AB-006-WH also features foil and braid shielding that ensures reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Gold-plated connectors provide maximum conductivity and minimum data loss to guarantee a clear transmission free of interference. Integral strain relief gives the cable extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. White Jacket Helps Avoid Misidentification That Can Cause Costly Downtime The cable has a white PVC jacket, which is easy to identify quickly in a crowded computer or hub and helps prevent the cable from becoming accidentally disconnected. Specifications OVERVIEW 1/3 Package Includes U024AB-006-WH USB-A Antibacterial Extension Cable (M/F), White, 6 ft. (1.8 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332260628 Technology USB 2.0 (High Speed) Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.5MM Wire Gauge (AWG) 28/24 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.07 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) Connector Plating Gold Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS Antimicrobial No USB Specification USB 2.0 (up to 480 Mbps) Antibacterial Yes STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U024AB-006-WH 价格&库存
很抱歉,暂时无法提供与“U024AB-006-WH”相匹配的价格&库存,您可以联系我们找货
