U040-006-C
U040-006-C
    TRIPPLITE
    USB 2.0 缆线 C 公型至 C 公型 6.00'(1.83m) 屏蔽
U040-006-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Cable (M/M) - USB 2.0, 6 ft. (1.83 m) MODEL NUMBER: U040-006-C Highlights ● Connects two USB-C devices ● Supports USB 2.0 data transfer speeds up to 480 Mbps ● Provides power output up to 3A ● Features reversible USB-C male plugs on both ends ● Works with previous USB generations System Requirements ● Devices with a USB Type-C port Package Includes ● Connect two devices with USB Type-C (USB-C) connectors, such as smartphones, tablets, Ultrabooks and computers. Description The U040-006-C USB 2.0 Hi-Speed Cable connects two devices with USB-C connectors—such as smartphones, tablets, Ultrabooks and computers—or a USB-C device to a wall charger with a USB-C port. This 6-ft. (1.83 m) cable supports data transfer speeds up to 480 Mbps and power output up to 3A for fast charging of mobile devices. Unlike traditional USB cables that can be attached only one way, the reversible USB-C male connectors plug into a USB port in either direction for fast, fumble-free connection every time. Superior foil shielding provides reliable, error-free data communication. Nickel-plated molded end connectors and gold-plated copper contacts ensure superior conductivity and long life. Slim form supports evolving design trends toward smaller devices. Backward compatible with previous USB generations. Features Supports USB 2.0 ● Data transfer speeds up to 480 Mbps ● Power output up to 3A—perfect for fast charging of most mobile devices ● Backward compatible with previous USB generations USB Type-C Male Connector ● Fumble-free reversible plug ensures fast, easy connection every time ● Powerful enough for smartphones, tablets, computers and other larger platforms Premium Construction ● Gold-plated copper contacts and nickel-plated molded ends provide a lifetime of heavy use and superior conductivity ● Superior foil shielding offers reliable, error-free data communication ● Slim, sleek design tailored for emerging design trends toward smaller devices Specifications 1/3 U040-006-C USB 2.0 Hi-Speed Cable, USB Type-C to USB Type-C M/M, 6-ft. (1.83 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332190154 Technology USB 2.0 (High Speed) Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.5MM Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -4° to 185°F (-20° to 85°C) Relative Humidity 10% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U040-006-C
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
U040-006-C 价格&库存
很抱歉,暂时无法提供与“U040-006-C”相匹配的价格&库存,您可以联系我们找货
