U040-006-C-FL
U040-006-C-FL
    TRIPPLITE
    USB 2.0 缆线 C 公型至 C 公型 6.00'(1.83m) 无屏蔽
U040-006-C-FL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Flat Cable (M/M), USB 2.0, Black, 6 ft. (1.83 m) MODEL NUMBER: U040-006-C-FL Highlights ● Flexible flat design helps prevent inconvenient tangling and allows easy bending ● Supports USB 2.0 speeds up to 480 Mbps to ensure efficient charging and data transfers ● Supports 3A (60W) power output for charging, syncing and powering mobile devices ● Reversible USB-C plugs connect in either direction for immediate no-fuss use ● Flat USB-C cable is compatible with all USB-C and Thunderbolt 3 devices Applications Flat USB cable connects a smartphone or other USB-C device to the USB-C port on your computer, charger or power bank. Features Flat USB 2.0 Cable Charges and Syncs Your Phone or Other USB-C Mobile DeviceThis USB sync/charge cable (M/M) connects your smartphone, tablet, MacBook Pro, Windows laptop or other USBC device to the USB-C port on a computer, docking station or wall charger. It supports power output up to 3 amps (60 watts), which is sufficient for fast charging and powering most mobile devices. It also simultaneously synchronizes and transfers data at USB 2.0 speeds up to 480 Mbps. ● Charge and power your MacBook Pro, Windows laptop or other USB-C or Thunderbolt 3 device from a USB-C wall charger up to 6 ft. away ● Transfer data between an external hard drive and your laptop or PC ● Connect your laptop to a docking station or hub with a USB-C or Thunderbolt 3 port ● Roll tightly for convenient carrying in your laptop bag, backpack or briefcase as a flexible spare cable Innovative Flat Cable Prevents Tangles, Allows Flexible BendsVery flexible for convenient on-the-go connections, this flat cable avoids nasty tangles in your backpack or laptop bag. Its advanced flat design allows easy rolling for tangle-free storage. Plus, it bends easily for connecting to devices in tight spaces or around obstacles. System Requirements Reversible USB-C Connectors Attach in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible USB-C male connectors plug into a USB-C or Thunderbolt 3 port in either direction for an instant connection every time. Package Includes Specifications OVERVIEW UPC Code 037332254016 Technology USB 2.0 (High Speed) Cable Type Passive INPUT 1/3 ● ● Devices with USB-C or Thunderbolt 3 ports U040-006-C-FL USB-C to USBC Cable, M/M, Black, 6 ft. (1.8 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 3 Maximum Input Watts 60 POWER USB Power Delivery (PD) Charging Support Yes PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 2.1*6.8MM Wire Gauge (AWG) 30/22 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.38 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85%, Non-Condensing Storage Humidity Range 5% to 90%, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U040-006-C-FL 价格&库存
很抱歉,暂时无法提供与“U040-006-C-FL”相匹配的价格&库存,您可以联系我们找货
