U060-001-KPA-WH
U060-001-KPA-WH
    TRIPPLITE
    USB 2.0 缆线 A 母头转 A 母头,成角度 1.00'(304.8mm) 屏蔽
U060-001-KPA-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 2.0 All-in-One Keystone/Panel Mount Coupler Cable (F/F), Angled Connector, White, 1 ft. (0.31 m) Highlights ● Angled female connector allows more flexible installation in tight spaces ● Gold-plated contacts for max conductivity and minimum data loss ● Optional panel mount adapter secures to podium or kiosk ● Keystone design snaps easily into standard wall plate or panel ● White in color to match most common wall plates MODEL NUMBER: U060-001-KPA-WH Package Includes ● 1 ft. cable with angled connector adds a USB-A female port to a fixed location, such as a keystone wall plate or panel. Optional panel mount adapter included for installation in a motherboard, podium or kiosk. Features Mounts a USB 2.0 Female Port in a Fixed Location ● USB-A female keystone jack snaps easily into wall plate or panel ● Optional panel mount adapter allows installation in motherboard, podium or kiosk ● Hides components out of sight to eliminate cable clutter ● Angled female connector permits more flexible installation in tight spaces ● White in color to match most common wall plates Premium Construction for Superior Signal Transfer ● Premium foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Molded connectors with gold-plated contacts provide maximum conductivity and minimize data loss ● Integral strain relief helps cable and connectors move freely without stress or cracking ● Rugged PVC jacket protects twisted 28/24 AWG data/power lines ● Heavy-duty plastic housings designed for durability and long life Specifications OVERVIEW UPC Code 037332209917 Technology USB 2.0 (High Speed) 1/3 U060-001-KPA-WH USB 2.0 Allin-One Keystone/Panel Mount Coupler Cable (F/F), White, 1 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Color White Connector Color White Cable Outer Diameter (OD) 0.15 mm Cable Length (ft.) 1 Cable Length (m) 0.30 Cable Length (in.) 12 Cable Length (cm) 30.48 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.07 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Relative Humidity 10% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (FEMALE) Side B - Connector 1 USB A (FEMALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U060-001-KPA-WH 价格&库存
很抱歉,暂时无法提供与“U060-001-KPA-WH”相匹配的价格&库存,您可以联系我们找货
