U280-W01-20C1-G
U280-W01-20C1-G
    TRIPPLITE
    壁插式 USB 电池充电器 5V,9V 3A
U280-W01-20C1-G 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Compact 1-Port USB-C Wall Charger - GaN Technology, 20W PD3.0 Charging, White MODEL NUMBER: U280-W01-20C1-G Highlights ● Ideal for charging smartphones, tablets, e-readers and laptops while traveling ● USB-C PD 3.0 port supports a maximum power capacity of 20W for fast charging ● Gallium nitride (GaN) technology generates less heat to support high-efficiency charging ● Connects to any NEMA 1-15R, 5-15R or 5-15/20R AC outlet for immediate charging ● Measures less than 2.5 cu. in., making it perfectly sized for convenient travel use Applications Travel-sized USB-C charger provides up to 20W to quickly and efficiently charge your smartphone or laptop at home or on the move. Features 20W USB Type-C Charger Gets Your Mobile Device Ready in a Hurry, Wherever You Are This single-port USB charger lets you quickly and safely charge your USB-C mobile device. Plug it into any NEMA 1-15R, NEMA 5-15R or NEMA 5-15/20R AC outlet to ensure your laptop, smartphone, tablet or other USB-C device charges at its fastest possible speed. The USB-C port supports USB Power Delivery (PD) 3.0 charging up to 5V 3A (15W) and 9V 2.22A (20W). Gallium Nitride Technology Allows High-Wattage Capacity in a Compact Package This USB wall charger is smaller and lighter than most standard wall chargers that come with a laptop, measuring less than 2.5 cubic inches. Ideal for travel, it is designed using GaN technology, which has a higher power density than silicon and provides higher efficiency than standard USB-C fast chargers. It also operates under much cooler temperatures, despite its small size, meaning it won’t get hot while charging your device. Built-In Auto-Sensing Adjusts to Proper Power Level to Get Your Device to 100% The USB-C port features auto-sensing technology that automatically adjusts to your device’s appropriate power level, perfect for fast-charging tablets and e-readers. The unit protects against overheating, overcurrent, overcharging and short circuits. In fact, it stops charging as soon as your device’s batteries are at full capacity. Folding Plug Design Perfectly Sized for Travel The compact USB Type-C charger, small enough to fit in the palm of your hand, is easy to carry in your purse, suitcase, backpack or laptop bag. The NEMA 1-15P plug folds into the unit when not in use to shield it from damage and prevent it from snagging or scratching your bag’s contents. Specifications OVERVIEW UPC Code 037332259899 1/4 Charge a smartphone, tablet, laptop or other USB-C mobile device without taking up a valuable USB port on your computer Package Includes U280-W01-20C1-G USB-C Wall Charger with PD Charging 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Wall Charger Charging Form Factor Direct Plug-In Device Compatibility Computer Technology USB INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Input Connection Type NEMA 1-15P Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50 / 60 Hz Input Plug Type NEMA 1-15P (NON-POLARIZED) Input Current 100-240V, 1.0A (Max) OUTPUT Overload Protection Yes POWER Power Consumption (Watts) 20 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue - Power CHARGING Number of Charging Ports 1 Total Charging Amps 3A Total Charging Watts 20 Charging Method USB Charging Method Detail Power Delivery 3.0 Charging Port Type USB C (FEMALE) Charging Ports Details 5V/3A (15W), 9V/2.22A (20W) Charging Ports / Amps (1) 3A Compatible Devices Smartphone; Tablet PHYSICAL Color White 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Material of Construction PC (Plastic) Unit Dimensions (hwd / in.) 1.090 x 1.560 x 1.360 Unit Dimensions (hwd / cm) 2.77 x 3.95 x 3.45 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 0° to 77°F (0° to 25°C) Storage Temperature Range -4° to 185°F (-20° to 85°C) Operating Humidity Range 20 to 90% RH, Non-Condensing Storage Humidity Range 5 to 95% RH, Non-Condensing Power Provided to Connected Device(s) USB-C: 5V/3A (15W), 9V/2.22A (20W) CONNECTIONS Number of Ports 1 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side B - Connector 1 USB C (FEMALE) FEATURES & SPECIFICATIONS GaN Technology Yes Overcurrent Protection Yes Overvoltage Protection Yes Over Current Protection Yes Quick Charge Compliant No Driver Required No STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL Listed Product Compliance RoHS; REACH; WEEE; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U280-W01-20C1-G 价格&库存
很抱歉,暂时无法提供与“U280-W01-20C1-G”相匹配的价格&库存,您可以联系我们找货
