U280-W01-18C1-K
U280-W01-18C1-K
    TRIPPLITE
    壁插式 USB 电池充电器 5V,9V 3A
U280-W01-18C1-K 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Compact USB-C Wall Charger with USB-C to Lightning Cable - 18W PD Charging, GaN Technology, White Highlights ● Ideal for charging iPod, iPad, iPhone and other Apple mobile devices ● USB-C PD 3.0 port supports a maximum capacity of 18W for fast charging ● Gallium nitride (GaN) technology generates less heat to support high-efficiency charging ● Connects to any NEMA 1-15R, 5-15R or 5-15/20R AC outlet for immediate charging ● Charger with folding plug perfectly sized for traveling in your backpack or purse MODEL NUMBER: U280-W01-18C1-K Applications Charge your Apple iPhone, iPad or iPod without taking up a valuable USB port on your computer Package Includes Travel-sized USB-C charger with included Lightning cable provides up to 18W to charge your iPhone or other Apple mobile device. Features 18W USB Type-C Charger Gets Your Mobile Device Ready in a Hurry, Wherever You Are This single-port USB charger lets you quickly and safely charge your Apple mobile device, including iPhone, iPad and iPod devices. Plug the charger into any NEMA 1-15R, NEMA 5-15R or NEMA 5-15/20R AC outlet to ensure your device charges at its fastest possible speed. The USB-C port supports USB Power Delivery (PD) 3.0 charging up to 18W (5V 3A and 9V 2A). Both Ends Feature Reversible Connectors Connect the reversible C94 Lightning plug to your Apple device for charging and the reversible USB-C connector to the wall charger. The cable’s fumble-free plugs connect in either direction to ensure an immediate connection on the first try. The Lightning cable is MFi-certified for use with the latest generation of iPhone, iPad and iPod devices. Gallium Nitride Technology Allows High-Wattage Capacity in a Compact Package This USB wall charger is smaller and lighter than most standard wall chargers that come with a laptop, measuring less than 2.5 cubic inches (4.1 cubic meters). Ideal for travel, it is designed using GaN technology, which has a higher power density than silicon and provides higher efficiency than standard USB-C fast chargers. It also stays cool during operation, despite its small size, meaning it won’t get hot while charging your device. Built-In Auto-Sensing Adjusts to Proper Power Level to Get Your Device to 100% The USB-C port features auto-sensing technology that automatically adjusts to your device’s appropriate power level. The unit protects against overheating, overcurrent and overcharging. In fact, it stops charging as soon as your device’s battery is at full capacity. Folding Plug Design Perfectly Sized for Travel The compact USB Type-C charger, small enough to fit in your hand, is easy to carry in your purse, suitcase or backpack. The NEMA 1-15P plug folds into the unit when not in use to shield it from damage and prevent it from snagging or scratching your bag’s contents. 1/4 ● USB-C wall charger ● USB-C to Lightning cable (M/M), 4 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332260765 Charging Form Factor Direct Plug-In Product Type Wall Charger Device Compatibility Phone; Tablet Technology USB INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Input Connection Type NEMA 1-15P Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50 / 60 Hz Input Plug Type NEMA 1-15P (NON-POLARIZED) Input Current 1.0A (Max) OUTPUT Overload Protection Yes POWER Power Consumption (Watts) 18 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue - Power CHARGING Number of Charging Ports 1 Total Charging Amps 3A Total Charging Watts 18 Charging Method USB Charging Method Detail Power Delivery 3.0 Charging Port Type USB C (FEMALE) Charging Ports Details 5V 3A (15W), 9V 2A (18W) 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Ports / Amps (1) 3A Compatible Devices Smartphone; Tablet PHYSICAL Color White Material of Construction PC (Plastic) Cable Jacket Color White Unit Dimensions (hwd / in.) 1.550 x 1.360 x 1.090 Unit Dimensions (hwd / cm) 3.95 x 3.45 x 2.77 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32° to 77°F (0° to 25°C) Storage Temperature Range -4° to 185°F (-20° to 85°C) Operating Humidity Range 20 ~ 90% RH, Non-Condensing Storage Humidity Range 5 ~ 95% RH, Non-Condensing Power Provided to Connected Device(s) USB-C: 5V 3A (15W), 9V 2A (18W) CONNECTIONS Number of Ports 1 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side B - Connector 1 USB C (FEMALE) FEATURES & SPECIFICATIONS GaN Technology Yes Overcurrent Protection Yes Overvoltage Protection Yes Over Current Protection Yes Quick Charge Compliant No Driver Required No STANDARDS & COMPLIANCE Product Certifications MFi; NOM (Mexico); UL Listed Product Compliance RoHS; REACH; WEEE; FCC (USA) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U280-W01-18C1-K 价格&库存
很抱歉,暂时无法提供与“U280-W01-18C1-K”相匹配的价格&库存,您可以联系我们找货
