U325-010
U325-010
    TRIPPLITE
    USB 3.0(USB 3.1 Gen 1,Superspeed) 缆线 A 公型至 A 公型 10.00'(3.05m) 屏蔽
U325-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Important Note ● Male-to-male is not a standard USB cable configuration. It’s used only in rare instances where a peripheral or patch bay employs a female connector instead of a USB-B port. This cable will not connect two PCs. File-sharing between computers requires special software-driven cables. Supports USB 3.0 speeds up to 5 Gbps to ensure fast data transfers ● Backward compatible with legacy USB 2.0 and USB 1.1 peripherals ● Foil/braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Integral strain relief helps cable move freely without stress or cracking ● Plug-and-play operation with no drivers required for easy, immediate installation USB 3.0 SuperSpeed A to A Cable for USB 3.0 All-in-One Keystone/Panel Mount Couplers (M/M), Black, 10 ft. (3 m) MODEL NUMBER: U325-010 System Requirements ● Computer with USB-A female port ● Peripheral or patch bay with USB-A female port Package Includes ● Connects peripherals, patch bays and Tripp Lite USB All-in-One Keystone/Panel Mount Couplers with female USB-A ports to your computer, laptop or other compatible USB device, such as a Chromebook™ or Microsoft® Surface®. Features USB Cable Connects USB Type-A Peripherals to Your Computer This USB-A to USB-A cable is ideal for connecting high-speed USB 3.0 equipment, such as a patch bay or other USB peripherals, to your computer, laptop or other compatible device, such as a Chromebook or Microsoft Surface. Additionally, the U325-010 cable is recommended for use with U325-000-KP-BK, U325-000-KPA-BK and U325-001-KPA-BK USB couplers. Supports USB 3.0 Speeds for a Faster, More Efficient Signal The U325-010 supports USB 3.0 data transfer rates up to 5 Gbps—10 times faster than USB 2.0. Its bidirectional data interface allows data to flow both directions simultaneously, increasing theoretical bandwidth by 10 times for efficient power and little wait-time. The U325-010 is also backward compatible with previous USB generations, so you can continue to use legacy USB 2.0 and USB 1.1 peripherals. Filtering EMI/RFI Line Noise and Eliminating Cable Strain Help Your Equipment Perform Better Foil and braid shielding blocks disruptive EMI (electromagnetic interference) and RFI (radio frequency interference) line noise that can disturb your electronics and inflict hardware damage or data loss. Integral strain relief gives the U325-010 extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from the connector. Specifications 1/3 U325-010 USB 3.0 SuperSpeed A/A Cable (M/M), Black, 10 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332274571 Technology USB 3.x Host Connector USB A (MALE) Cable Type Passive PHYSICAL Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5mm Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 10% TO 90% RH, Non-Condensing Storage Humidity Range 10% TO 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U325-010 价格&库存
很抱歉,暂时无法提供与“U325-010”相匹配的价格&库存,您可以联系我们找货
