U328F-20M
U328F-20M
    TRIPPLITE
    USB 3.2 第 1(USB 3.1 第 1,Superspeed(USB 3.0)) 缆线 A 公型至 B 公型 65.62'(20.00m) 无屏蔽
U328F-20M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.2 Gen 1 Plenum-Rated Fiber Active Optical Cable (AOC) - 5 Gbps, (A to B M/M), Black, 20 m Highlights ● Ideal for long-distance USB connections that can’t be supported by copper cabling ● Supports USB 3.2 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● 20 m (66 ft.) length allows flexibility in placing USB devices where best needed ● Plenum rated for horizontal premise applications in air ducts and drop ceilings ● Plug-and-play cable draws power from connected device for easy installation MODEL NUMBER: U328F-20M Applications Connect a printer, external hard drive or other USB-B peripheral to the USB-A port on your PC, tablet, laptop or notebook High-speed in-wall fiber cable connects USB printers and other USB-B devices to the USB-A port on your computer up to 20 meters away. Features USB-A to USB-B Cable Connects Home and Office Components This USB fiber optic cable (M/M) securely connects the USB-A port on your desktop, laptop or notebook computer to a USB-B device, such as a printer, scanner or external drive, located up to 20 meters away. It supports USB 3.2 Gen 1 transfer rates up to 5 Gbps, which is 10 times faster than USB 2.0, for transmitting data only. Note: this USB cable is not backward compatible with USB 2.0 or USB 1.1 devices. Advanced Fiber Cable Is Easier to Install than Copper Because the fiber cable is slimmer and more flexible than standard copper USB cables, the U328F-20M is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the connected device, so no external power supply is needed to transmit the USB signal across the longer distances unique to fiber optic cabling. CMP Jacket Designed for In-Wall Installations The plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. 20 m (66 ft.) Cable Lets You Design an Application to Your Custom Specifications This long cable allows you greater flexibility in placing your USB components. For instance, your printer or scanner may be located in a different room away from your office or in a central location where others have access to it. The plug-and-play U328F-20M supports all major operating systems, including Windows, macOS and Linux. Specifications OVERVIEW UPC Code 037332260277 1/3 Package Includes U328F-20M USB 3.2 Gen 1 Fiber Active Optical Cable, M/M, Black, 20 m (66 ft.) 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology USB 3.x Cable Type Active INPUT Maximum Input Amps 1 POWER USB Power Delivery (PD) Charging Support No CHARGING Total Charging Watts 4.5 PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating CMP Cable Outer Diameter (OD) 4.5mm Wire Gauge (AWG) 18 Cable Length (ft.) 65 Cable Length (m) 19.82 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Operating Humidity Range 5% - 90% RH, Non-Condensing Storage Humidity Range 5% - 90% RH, Non-Condensing Power Provided to Connected Device(s) 5V, 900mA CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 3.2 Gen 1 (up to 5 Gbps) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Data Transfer Rate 5 Gbps Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U328F-20M 价格&库存
很抱歉,暂时无法提供与“U328F-20M”相匹配的价格&库存,您可以联系我们找货
