U336-000-GB-CA
U336-000-GB-CA
    TRIPPLITE
    缆线组件 USB A 公插头,USB C 公插头转 RJ45 0.49'(150.0mm)
U336-000-GB-CA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C, USB-A to RJ45 Gigabit Ethernet Network Adapter (2xM/F), USB 3.2 Gen 1, Black Highlights ● Connects you to a wired 10/100/1000 Mbps network where Wi-Fi is weak or unavailable ● More convenient, less expensive than installing or upgrading an internal Ethernet card ● Widely compatible with Windows and macOS operating systems ● LED indicates successful connection to computer and an Ethernet network ● Plug-and-play operation with no external power needed for easy, immediate installation MODEL NUMBER: U336-000-GB-CA Applications ● Connect to a wired Gigabit Ethernet network in an office, trade show booth, lecture hall, classroom, hotel lobby or auditorium ● Extend the life of a legacy laptop or notebook computer with a failed internal Ethernet card ● Play network gaming consoles in areas without Wi-Fi capability Connects your PC, Chromebook, MacBook Pro or Windows laptop to a wired Gigabit Ethernet network at 1 Gbps speeds. Features USB to Gigabit Ethernet Adapter Connects You to a Wired 1G Network This USB network adapter instantly connects your computer, notebook, MacBook Pro or Windows laptop to a wired Gigabit network through either a USB-A or USB-C port. No internal Ethernet card is required. Ideal for settings in which no Wi-Fi is available or when a wired connection offers faster speeds, this USB 3.2 Gen 1 adapter lets you enjoy true 10/100/1000 Mbps Ethernet speeds for uploading and downloading large files and streaming audio/video without buffering. Plug-and-Play Operation Gets You Online Immediately This bus-powered network adapter requires no external power source. Just connect the built-in USB-A plug to your computer (a USB-C adapter is included for connecting a USB-C or Thunderbolt 3 port), and use a Cat6 cable (such as Tripp Lite’s N201-Series) to connect the RJ45 end to a network. LEDs indicate when the adapter is connected to your computer and your computer is connected to a network. Complies with Current IEEE Standards The U336-000-GB-CA is compliant with IEEE 802.3, 802.3u, 802.3ab and 802.3az standards. It supports full duplex with IEEE 802.3x flow control and half duplex with back-pressure flow control, as well as 10/100/1000 auto-sensing, Wake-on-LAN and IPv4 and IPv6 pack Checksum Offload Engine (COE) to reduce CPU loading. The compact unit fits easily into a pocket, purse, backpack or laptop bag for instant file transfers where needed. It’s compatible with Windows and macOS. Specifications OVERVIEW UPC Code 037332266934 Technology Cat5/5e; Cat6; Cat6a; USB 2.0 (High Speed); USB 3.x 1/3 System Requirements ● PC, laptop or other compatible device with USB-A or USB-C port (USB 3.2 Gen 1 required to achieve USB 3.2 Gen 1 speeds) ● Windows or macOS operating system Package Includes ● U336-000-GB-CA USB-C/USBA to RJ45 Gigabit Ethernet Network Adapter ● USB-A to USB-C adapter (F/M) ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Built-In Cable Length (ft.) 0.328 Built-In Cable Length (m) 0.1 Built-In Cable Length (in.) 3.937 Product Length (in.) 5.905 Product Length (cm.) 15 Product Length (ft.) 0.492 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) No POWER USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators White (Connection to Power); Orange (Activity) CHARGING Total Charging Amps 3A Total Charging Watts 20 Charging Ports / Amps 3A PHYSICAL Color Black Material of Construction PC (Plastic) Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9mm Wire Gauge (AWG) 32 + 28 Shipping Dimensions (hwd / in.) 4.72 x 3.94 x 0.78 Shipping Weight (lbs.) 0.11 Unit Dimensions (hwd / in.) 1.968 x 0.846 x 0.570 Unit Dimensions (hwd / cm) 5.0 x 2.15 x 1.45 Unit Packaging Type Polybag Unit Weight (lbs.) 0.088 Unit Weight (kg) 0.04 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Operating Humidity Range 10 to 85% RH, Non-Condensing Storage Humidity Range 5 to 90% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3; 802.3ab; 802.3az; 802.3u CONNECTIONS Number of Ports 1 Side A - Connector 1 USB A (MALE) Side A - Connector 2 USB C (MALE) Side B - Connector 1 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 1.1 (up to 12 Mbps); USB 2.0 (up to 480 Mbps); USB 3.0 (up to 5 Gbps) Driver Required No Recommended Category Cable Cat6/6a Remote Wakeup Support Yes Network Speed Support 1 Gbps (Gigabit) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; WEEE; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U336-000-GB-CA 价格&库存
很抱歉,暂时无法提供与“U336-000-GB-CA”相匹配的价格&库存,您可以联系我们找货
U336-000-GB-CA
  • 1+335.734831+43.47082
  • 10+297.8055010+38.55975
  • 25+283.9458525+36.76521
  • 50+273.8952350+35.46386
  • 100+264.20133100+34.20869
  • 250+251.91388250+32.61772
库存:50
