U359-002
U359-002
    TRIPPLITE
    2-PORT USB 3.0 PERIPHERAL SHARIN
U359-002 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 2-Port USB 3.x (5Gbps) Peripheral Sharing Switch MODEL NUMBER: U359-002 Highlights ● Share a printer, scanner, hard drive, webcam or other USB device with 2 computers ● Supports SuperSpeed USB 3.0 speeds up to 5 Gbps to ensure fast data transfers ● Easy one-touch control lets you switch between computers using manual buttons ● Backward compatible with USB 2.0 and 1.1 devices, so you can use older peripherals ● Plug-and-play operation with no software required for easy, immediate installation Applications ● Switch one printer or scanner between 2 computers to save space in the office ● Connect an external hard drive, so both computers can access the same data ● Control 2 computers using the same USB keyboard/mouse combo ● Connect a webcam or security camera to monitor inventory or an office lobby from multiple computers Connects a single USB printer or other peripheral to 2 computers simultaneously to save time, money and precious workspace. Features USB Sharing Switch Connects 2 Computers to One USB Printer, Scanner or Other DeviceThis compact 2-port USB peripheral-sharing switch lets you share one USB 3.0 peripheral between two computers in your home or small office. This eliminates the cost and effort of picking out and buying two printers, two scanners, two external hard drives, etc., as well as the problem of where to put them and their cables. By sharing a USB 3.0 printer or webcam between two computers, you save time, money and precious workspace. Maximum distance from host device to peripheral is 16-ft. (4.88 m). Supports SuperSpeed USB 3.0 to Ensure Fast Data TransfersThis USB 3.0 sharing switch supports USB 3.0 data transfer rates up to 5 Gbps, which is 10 times faster than USB 2.0. It is especially recommended for high-bandwidth USB 3.0 devices, such as security cameras and high-resolution webcams. The USB 3.0 peripheral-sharing switch is backward compatible with previous USB generations, so you can continue using older peripherals while getting maximum performance from current devices. Switch Between Computers with a Quick Touch of a ButtonEasy one-touch port switching lets you switch from one computer to the other just by pressing the buttons on top of the unit. Blue LEDs indicate which computer is currently in control of the connected USB 3.0 peripheral. Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe USB sharing switch requires no external power supply or software and drivers to download and install. Just connect your USB 3.0 peripheral device to the switch's USB-A port and the computers to the switch's USB-B ports with user-supplied USB 3.0 cables. The USB 3.0 sharing switch supports all USB-enabled operating systems. Specifications OVERVIEW UPC Code 037332224774 1/3 System Requirements ● Up to 2 computers with USB-A ports ● Peripheral with USB-A port Package Includes ● U359-002 2-Port USB 3.0 Peripheral Sharing Switch SuperSpeed ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology USB 3.x Host Connector USB A (MALE) VIDEO Extended Mode No Mirror Mode No DATA Data Ports USB A (FEMALE) INPUT Bus Powered Yes USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Display Control) PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 1.46 x 3.07 x 2.48 Shipping Dimensions (hwd / cm) 3.71 x 7.80 x 6.30 Shipping Weight (lbs.) 0.14 Shipping Weight (kg) 0.06 Unit Dimensions (hwd / in.) 2.800 x 2.200 x 0.800 Unit Dimensions (hwd / cm) 7.1 x 5.6 x 2 Unit Packaging Type Box Unit Weight (lbs.) 0.01 Unit Weight (kg) 0.00 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 14° to 131°F (-10° to 55°C) Operating Humidity Range 5% to 90% RH, Non-Condensing Storage Humidity Range 5% to 95% RH, Non-Condensing CONNECTIONS Number of Ports 3 Side A - Connector 1 USB 3.0 A (FEMALE) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 (2) USB 3.0 B (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 1 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Port Selection Pushbutton Driver Required No STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U359-002 价格&库存
很抱歉,暂时无法提供与“U359-002”相匹配的价格&库存,您可以联系我们找货
U359-002
    库存:6
