TLP6F18
TLP6F18
    TRIPPLITE
    6-OUTLET SURGE PROTECTOR - FRENC
TLP6F18 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-Outlet Surge Protector - French Type E Outlets, 220-250V AC, 16A, 1.8 m Cord, Type E Plug, White Highlights ● 6 Type E outlets distribute power to appliances, tools, lighting and other electronics ● Right-angle Type E plug permits connection in confined or hardto-reach spaces ● 250 joules protect your valuable electronics against dangerous surges and spikes ● 44.5 cm plastic housing designed to withstand the rigors of everyday use ● 16A circuit breaker shuts down all outlets for safety in case of overload MODEL NUMBER: TLP6F18 Applications ● Protect computers, peripherals, home theater equipment and other valuable electronics against AC power surges and spikes ● Filter potentially damaging line noise to improve connected equipment’s performance and lifespan ● Safeguard valuable data against damage stemming from unexpected surges 6-outlet surge protector safeguards your home/office electronics against dangerous surges, spikes and line noise. Features 6-Outlet Surge Protector Safeguards Your Sensitive Electronics Against Power FluctuationsIdeal for your home or office workstation, this Protect It!® 6-outlet surge protector features a surge suppression rating of 250 joules and provides protection in line-to-neutral (L-N) mode to defend your sensitive electronic components against power surges and spikes. Package Includes ● French Type E Outlets Accept a Wide Range of Electronic DevicesPlug your PC, printer, scanner, router, modem, television, stereo receiver or other home/office electronics into six Type E outlets to protect them against dangerous surges, spikes and line noise. The 1.8-meter AC power cord with spacesaving right-angle Type E plug helps you connect the surge protector to a wall outlet located behind furniture. Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform BetterVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems. This surge protector filters out disruptive line noise that can disturb your electronics and inflict hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform better and last longer. Premium Safety Features for Protecting Your Valuable EquipmentThe TLP6F18 features an on/off switch that provides one-touch control over all connected devices. A green LED confirms that your connected equipment is protected. In the event of an overload, a resettable 16-amp circuit breaker immediately shuts down the power strip to prevent equipment damage. The high-impact plastic housing is designed for the rigors of everyday use. Specifications OVERVIEW 1/3 TLP6F18 6-Outlet Surge Protector, French Type E Outlets, White 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332251527 INPUT Nominal Input Voltage(s) Supported 230V AC Recommended Electrical Service 230V (220-250V) Voltage Compatibility (VAC) 220-250 Maximum Surge Amps 250 Input Plug Type French Right-Angle Plug Yes Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) French/Belgian Circuit Breaker (amps) 16 Overload Protection combo switch/circuit breaker Outlet Orientation right-angled Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position power switch SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 250 Protection Modes Includes full normal mode (H-N) Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color White Housing Color White 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Mounting Holes or Slots Yes Receptacle Color White Shipping Dimensions (hwd / in.) 18.00 x 3.40 x 2.90 Shipping Dimensions (hwd / cm) 45.72 x 8.64 x 7.37 Shipping Weight (lbs.) 1.50 Shipping Weight (kg) 0.68 Unit Dimensions (hwd / in.) 17.500 x 2.900 x 2.000 Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
TLP6F18
PDF文档中的物料型号为MAX31855。
该器件是一个冷结补偿的K型热电偶到数字转换器,具有内部冷结补偿、宽工作温度范围和高精度等特点。
引脚分配如下:1脚为VDD,2脚为GND,3脚为SO,4脚为CS/#,5脚为CLK,6脚为DO,7脚为DGND,8脚为CREF,9脚为BREF,10脚为AREF,11脚为ALERT#。
参数特性包括供电电压范围2.0V至5.5V,转换速率0.25秒,分辨率0.0625°C等。
功能详解为MAX31855利用SPI接口与微处理器通信,支持多达8通道热电偶输入。
应用信息包括工业控制、医疗设备和环境监测等领域。
封装信息为TDFN-10封装。
TLP6F18 价格&库存
很抱歉,暂时无法提供与“TLP6F18”相匹配的价格&库存,您可以联系我们找货
