U420-003-G2-FL
U420-003-G2-FL
    TRIPPLITE
    USB 3.2 Gen 2(USB 3.1 Gen 2,Superspeed+(USB 3.1)) 缆线 C 公型至 C 公型 3.00'(914.4mm) 无屏蔽
U420-003-G2-FL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Flat Cable (M/M) - USB 3.2 Gen 2 (10 Gbps), Thunderbolt 3 Compatible, 3 ft. (0.91 m) MODEL NUMBER: U420-003-G2-FL Highlights ● Flexible flat design helps prevent inconvenient tangling and allows easy bending ● Supports USB 3.1 Gen 2 speeds up to 10 Gbps to ensure lightning-fast data transfers ● Provides 2.3A (46W) power output for charging, syncing and powering mobile devices ● Reversible USB-C plugs connect in either direction for immediate no-fuss use ● Flat USB-C cable is compatible with all USB-C and Thunderbolt 3 devices Applications Flat USB 3.1 Gen 2 cable connects a smartphone or other USB-C device to the USB-C port on your computer, charger or power bank. Features Flat USB-C Cable Transfers Data and Charges Devices at Lightning-Fast USB 3.1 Gen 2 SpeedsThis USB sync/charge cable (M/M) connects your smartphone, tablet, MacBook Pro, Windows laptop or other USB-C device to the USB-C port on a computer, docking station or wall charger. It supports USB 3.1 Gen 2 data transfer rates up to 10 Gbps, which is twice as fast as USB 3.1 Gen 1. It also provides power output up to 2.3 amps (46 watts), which is sufficient for charging and powering most mobile devices. Innovative Flat Cable Prevents Tangles, Allows Flexible BendsVery flexible for convenient on-the-go connections, this flat cable avoids nasty tangles in your backpack or laptop bag. Its advanced flat design allows easy rolling for tangle-free storage. Plus, it bends easily for connecting to devices in tight spaces or around obstacles. Reversible USB-C Connectors Attach in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible USB-C male connectors plug into a USB-C or Thunderbolt 3 port in either direction for an instant connection every time. Specifications OVERVIEW UPC Code 037332254030 Technology Thunderbolt; USB 3.x Cable Type Passive INPUT 1/3 ● Charge and power your MacBook Pro, Windows laptop or other USB-C or Thunderbolt 3 device from a USB-C wall charger ● Transfer data between an external hard drive and your laptop or PC ● Connect your laptop to a docking station or hub with a USB-C or Thunderbolt 3 port ● Carry in your laptop bag, backpack or briefcase as a flexible spare cable System Requirements ● Devices with USB-C or Thunderbolt 3 ports (USB 3.1 Gen 2 compatibility required to achieve USB 3.1 Gen 2 speeds) Package Includes ● U420-003-G2-FL Flat USB-C to USB-C Cable, M/M, Black, 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps 2.3 PHYSICAL Material of Construction TPE Cable Jacket Color Black Cable Jacket Material TPE Cable Outer Diameter (OD) 1.2*11.0MM Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 14° to 140°F (-10° to 60°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 10% to 85% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 3.1 Gen 2 (up to 10 Gbps) STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U420-003-G2-FL 价格&库存
很抱歉,暂时无法提供与“U420-003-G2-FL”相匹配的价格&库存,您可以联系我们找货
