U420F-10M-D321
U420F-10M-D321
    TRIPPLITE
    USB 3.2 第 1 代(USB 3.1 第 1 代,Superspeed(USB 3.0)),USB 3.2 第 2 代(USB 3.1 第 2 代,Superspeed +(USB 3.1)) ...
U420F-10M-D321 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C AOC Cable (M/M) - USB 3.2 Gen 2 (10 Gbps) Plenum-Rated Fiber Active Optical Cable Data Only, Backward Compatible, Black, 10 m (33 ft.) MODEL NUMBER: U420F-10M-D321 Highlights ● 10 m (33 ft.) length allows flexibility in placing USB-C devices where most needed ● Fiber optic construction ideal for long-distance connections not supported by copper ● USB 3.2 Gen 2 (10 Gbps) cable is backward compatible with earlier USB generations ● Plenum rated for horizontal premise applications in air ducts and drop ceilings ● Slim, flexible cable easily installs around corners and through hard-to-reach areas Package Includes U420F-10M-D321 USB 3.2 Gen 2 Fiber Active Optical Cable, M/M, 10 m (33 ft.) High-speed in-wall fiber cable connects a USB-C device to the USB-C port on your computer up to 10 meters away. Features Active Optical Cable Connects Servers, Hard Drives and Other USB-C Components This USB 3.2 Gen 2 fiber optic cable (M/M) securely connects the USB-C port on your desktop, laptop or notebook computer to a USB-C device, such as a server, external hard drive or surveillance camera, located up to 10 meters (33 feet) away. This data-only cable supports USB 3.2 Gen 2 data transfer rates up to 10 Gbps, and is backward compatible with USB 3.2 Gen 1, 2.0 and 1.1 devices. Advanced Fiber Cable Is Easier to Install than Copper Because the fiber cable is slimmer and more flexible than standard copper USB cables, the U420F-10MD321 is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power from the connected device, so no external power supply is needed to transmit the USB signal across the longer distances unique to fiber optic cabling. CMP Jacket Designed for In-Wall Installations The plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise applications in ceilings, walls and ducts. 10 m Cable Lets You Design an Application to Your Custom Specifications This long cable allows you greater flexibility in placing your USB components. For instance, your camera or hard drive may be located in a different room away from your office or in a central location where others have access to it. The plug-and-play U420F-10M-D321 supports all major operating systems, including Windows, macOS and Linux. Note: This data-only cable provides up to 1A of power to the connected device. If your device requires more than 1A of power, an external power supply will be required for the connected USB device. Specifications 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332275158 Technology USB 3.x Cable Type Active INPUT Bus Powered Yes POWER USB Power Delivery (PD) Charging Support No PHYSICAL Material of Construction PVC (Plenum-Rated Cable) + Zinc Alloy (Connector Ends) Cable Jacket Color Black Connector Color Light Gray Cable Jacket Material PVC Cable Jacket Rating CMP Cable Outer Diameter (OD) 4.5 mm Cable Length (ft.) 32.8 Cable Length (m) 10.00 Cable Length (in.) 393.7 Unit Dimensions (hwd / in.) 1.540 x 9.250 x 8.860 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32° to 122°F (0° to 50°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 5% TO 90% RH, NON-CONDENSING Operating Humidity Range 5% TO 90% RH, NON-CONDENSING Storage Humidity Range 5% TO 90% RH, NON-CONDENSING CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (MALE) Connector Plating Gold Contact Plating Gold 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 3.1 Gen 2 (up to 10 Gbps); USB 3.2 Gen 2 (Up to 10 Gbps) Data Transfer Rate 10 Gbps Driver Required No STANDARDS & COMPLIANCE Product Certifications CAN/CSA C22.2; EN 55032; UL Listed Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U420F-10M-D321 价格&库存
很抱歉,暂时无法提供与“U420F-10M-D321”相匹配的价格&库存,您可以联系我们找货
