1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C AOC Cable (M/M) - USB 3.2 Gen 2 (10
Gbps) Plenum-Rated Fiber Active Optical Cable Data Only, Backward Compatible, Black, 15 m (49
ft.)
MODEL NUMBER: U420F-15M-D321
Highlights
15 m (49 ft.) length allows
flexibility in placing USB-C
devices where most needed
Fiber optic construction ideal for
long-distance connections not
supported by copper
USB 3.2 Gen 2 (10 Gbps) cable
is backward compatible with
earlier USB generations
Plenum rated for horizontal
premise applications in air ducts
and drop ceilings
Slim, flexible cable easily installs
around corners and through
hard-to-reach areas
Package Includes
U420F-15M-D321 USB 3.2 Gen 2
Fiber Active Optical Cable, M/M,
15 m (49 ft.)
High-speed in-wall fiber cable connects a USB-C device to the USB-C port on your computer up to 15
meters away.
Features
Active Optical Cable Connects Servers, Hard Drives and Other USB-C Components
This USB 3.2 Gen 2 fiber optic cable (M/M) securely connects the USB-C port on your desktop, laptop or
notebook computer to a USB-C device, such as a server, external hard drive or surveillance camera,
located up to 15 meters (49 feet) away. This data-only cable supports USB 3.2 Gen 2 data transfer rates
up to 10 Gbps, and is backward compatible with USB 3.2 Gen 1, 2.0 and 1.1 devices.
Advanced Fiber Cable Is Easier to Install than Copper
Because the fiber cable is slimmer and more flexible than standard copper USB cables, the U420F-15MD321 is easier to install around corners and in hard-to-reach spaces behind equipment. It draws power
from the connected device, so no external power supply is needed to transmit the USB signal across the
longer distances unique to fiber optic cabling.
CMP Jacket Designed for In-Wall Installations
The plenum-rated jacket has low smoke and flame characteristics, making it suitable for premise
applications in ceilings, walls and ducts.
15 m Cable Lets You Design an Application to Your Custom Specifications
This long cable allows you greater flexibility in placing your USB components. For instance, your camera
or hard drive may be located in a different room away from your office or in a central location where others
have access to it. The plug-and-play U420F-15M-D321 supports all major operating systems, including
Windows, macOS and Linux. Note: This data-only cable provides up to 1A of power to the connected
device. If your device requires more than 1A of power, an external power supply will be required for the
connected USB device.
Specifications
1/3
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332275165
Technology
USB 3.x
Cable Type
Active
INPUT
Bus Powered
Yes
POWER
USB Power Delivery (PD) Charging
Support
No
PHYSICAL
Material of Construction
PVC (Plenum-Rated Cable) + Zinc Alloy (Connector Ends)
Cable Jacket Color
Black
Connector Color
Light Gray
Cable Jacket Material
PVC
Cable Jacket Rating
CMP
Cable Outer Diameter (OD)
4.5 mm
Cable Length (ft.)
49.2
Cable Length (m)
15.00
Cable Length (in.)
590.5
Unit Dimensions (hwd / in.)
1.540 x 9.250 x 8.860
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
32° to 122°F (0° to 50°C)
Storage Temperature Range
-4° to 158°F (-20° to 70°C)
Relative Humidity
5% TO 90% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
USB C (MALE)
Connector Plating
Gold
Contact Plating
Gold
2/3
Cleveland, OH 44122
United States
Connector Style
Straight
FEATURES & SPECIFICATIONS
USB Specification
USB 3.1 Gen 2 (up to 10 Gbps); USB 3.2 Gen 2 (Up to 10 Gbps)
Data Transfer Rate
10 Gbps
Driver Required
No
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA C22.2; EN 55032; UL Listed
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U420F-15M-D321”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1860.862431+241.20320
- 10+1581.9221410+205.04723
- 25+1536.8508425+199.20513
