U437-001
U437-001
    TRIPPLITE
    USB-C TO 3.5 MM HEADPHONE JACK A
U437-001 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to 3.5 mm Headphone Jack Adapter Highlights ● Adds a 3.5 mm headphone/mic port to a device that comes without a stereo audio jack ● Connecting to a USB-C port lets you bypass a defective sound card or audio jack ● Slim adapter fits into a backpack or laptop bag for convenient listening anywhere ● Plug-and-play operation with no software required for speedy installation ● Compatible with Android, Windows and macOS, including iPads with USB-C port MODEL NUMBER: U437-001 System Requirements Connects a microphone or stereo headphones to the USB-C or Thunderbolt 3 port on your MacBook Pro, Windows laptop or Chromebook. Features ● Microphone, headphones, earbuds and/or speakers with 3.5 mm plug ● Android, Windows or macOS (including iPad with USB-C port) Package Includes 3.5 mm Audio Adapter Connects to Your Laptop’s USB-C or Thunderbolt 3 Port This USB Type-C Stereo Audio Adapter allows you to connect a microphone, earbuds, headphones or speakers to your MacBook Pro, Windows laptop, Chromebook or other device with a USB-C or Thunderbolt 3 port. This adapter allows you to bypass a defective sound card or 3.5 mm headphone jack, as well as connect to a device that offers only USB-C ports. Ready to Use Right Out of the Package The plug-and-play audio adapter requires no software or external power. The slim cable fits easily into a pocket, purse, backpack, briefcase or laptop bag for connecting on the go. The 24-bit U437-001 converts digital high-resolution audio to analog at a 96 kHz sample rate to maintain a crisp, lively sound. Specifications OVERVIEW UPC Code 037332269669 Technology Stereo Audio AUDIO Audio Ports 3.5MM (FEMALE) Audio Ports Details USB-C to 3.5mm Audio Adapter Audio Input USB-C Audio Output 3.5mm Audio Specification DAC 96 kHz, 24-Bit 1/3 ● U437-001 USB-C to 3.5 mm Headphone Jack Adapter ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Built-In Cable Length (ft.) 0.66 Built-In Cable Length (m) 0.2 Built-In Cable Length (in.) 7.87 Built-In Cable Length (cm) 20 Bus Powered Yes Product Length (in.) 10.75 Product Length (cm.) 27.3 Product Length (ft.) 0.9 Product Length (m.) 0.27 BATTERY Battery Charging (5V/1.5A Port) No PHYSICAL Color Black Material of Construction PC, ABS, TPE Cable Jacket Color Black Cable Jacket Material TPE Cable Outer Diameter (OD) 2.5mm Cable Length (ft.) 0.43 Cable Length (m) 0.13 Cable Length (in.) 5.12 Cable Length (cm) 1.3 Shipping Dimensions (hwd / in.) 0.25 x 4.50 x 6.75 Shipping Weight (lbs.) 0.02 Unit Dimensions (hwd / in.) 0.510 x 1.100 x 1.810 Unit Dimensions (hwd / cm) 1.3 x 2.8 x 4.6 Unit Packaging Type Polybag Unit Weight (lbs.) 0 Unit Weight (kg) 0.00 ENVIRONMENTAL Operating Temperature Range -4° to 122°F (-20° to 50°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 20 ~ 80% RH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 1 Side A - Connector 1 USB C (MALE) Side B - Connector 1 3.5MM (FEMALE) Side B - Connector 2 (1) 3.5MM (FEMALE) FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U437-001 价格&库存
很抱歉,暂时无法提供与“U437-001”相匹配的价格&库存,您可以联系我们找货
