U421-003
U421-003
    TRIPPLITE
    USB 3.2 第 1(USB 3.1 第 1,Superspeed(USB 3.0)) 缆线 C 母头转 C 公头 3.00'(914.4mm) 无屏蔽
U421-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Extension Cable (M/F) - USB 3.2 Gen 1 (5 Gbps), Thunderbolt 3 Compatible, Black, 3 ft. (0.91 m) Highlights ● Power Delivery cable supports 20V 3A (60W) power output for charging host device ● Supports USB 3.2 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● Plug-and-play operation with no software required for easy, immediate installation ● USB-C to USB-C cable is compatible with all USB-C and Thunderbolt 3 devices MODEL NUMBER: U421-003 Applications ● Extend an existing USB connection up to 3 ft. to more easily place a device ● Transfer data between an external hard drive or flash drive and your laptop or computer ● Connect your laptop to a docking station or hub with a USB-C or Thunderbolt 3 port USB-C to USB-C extension cable extends the distance between two USB-C devices by 3 feet. System Requirements Features USB-C Cable Connects Devices for Charging or Transferring Data at 5 Gbps Speeds This USB extension cable (M/F) is compatible with any device with a USB-C or Thunderbolt 3 port, including MacBook Pros, Chromebooks and Windows laptops. The USB-C cable supports USB 3.2 Gen 1 data transfer speeds up to 5 Gbps, which is 10 times faster than USB 2.0. It is backward compatible with previous USB generations, so you can use it to connect legacy equipment. Extension Cable Connects Computers, Docks, Smartphones and Other USB-C Devices This cable allows you more flexibility in placing devices in your home or workspace by adding three feet (0.9 meters) to their connections. For instance, you can extend the connection between your notebook computer and docking station, your Apple or Android device and wall charger or power bank, or an external hard drive and PC or tablet, to name just a few. PD Charging Cable Supports up to 60W for Syncing and Charging Mobile Devices The Power Delivery cable provides power output up to 20V 3A (60W), which is sufficient for fast charging, syncing and powering most smartphones and other mobile devices. Specifications OVERVIEW UPC Code 037332266422 Technology Thunderbolt; USB 3.x Cable Type Passive INPUT Maximum Input Amps 3 1/3 Devices and cable with USB-C or Thunderbolt 3 connectors (USB 3.2 Gen 1 capability required to reach USB 3.2 Gen 1 speeds) Package Includes U421-003 USB-C Extension Cable, M/F, Black, 3 ft. (0.9 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Watts 60 POWER USB Power Delivery (PD) Charging Support Yes PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.2MM Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 60W (20V/3A) CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 USB C (FEMALE) Connector Plating Nickel Contact Plating Nickel Connector Style Straight FEATURES & SPECIFICATIONS USB Specification USB 3.2 Gen 1 (up to 5 Gbps) STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U421-003 价格&库存
很抱歉,暂时无法提供与“U421-003”相匹配的价格&库存,您可以联系我们找货
