U442-DOCK20BINT
U442-DOCK20BINT
    TRIPPLITE
    USB-C DOCK, DUAL DISPLAY - DUAL
U442-DOCK20BINT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Device Drivers ● A driver CD-ROM is no longer included with this product. The latest drivers for Windows, macOS, Android, Chrome OS and Ubuntu are available from the DisplayLink website. Please visit https://www.displaylink.com/downloads. Connects 2 external displays for easy multitasking and increasing productivity ● Supports 20V 4.25A (85W) power output for fast-charging large-capacity mobile devices ● Joins a wired 10/100/1000 Gigabit Ethernet network when no Wi-Fi is available ● USB 3.2 Gen 1 Type-A data ports allow connection of flash drives and other peripherals ● Included USB-C to A adapter can connect to host device’s USB-A port, if desired USB-C Dock, Dual Display - Dual HDMI, USB 3.x (5Gbps) Hub, GbE, 3.5 mm, 85W PD Charging, EU/UK Power Adapters MODEL NUMBER: U442-DOCK20BINT System Requirements ● Source device with USB-A, USB-C or Thunderbolt 3 port and DisplayLink drivers installed ● Display device with HDMI input ● Windows or macOS operating system Package Includes USB-C dock with DisplayLink technology connects 2 HDMI monitors to your host device and extends/mirrors video to them simultaneously. ● U442-DOCK20BINT USB-C Dock, Dual Display, Black ● USB-C cable, 1 m ● USB-C to USB-A adapter ● External power supply (Input: 100–240V, 50/60 Hz, 2A; Output: 20V 5A) ● (2) International power adapters (BS 1363 U.K., CEE 7/7 Schuko EU) ● Owner’s manual Features USB-C Docking Station Turns Your Device’s USB or Thunderbolt 3 Port into a Workstation This multiport USB-C dock with PD Charging expands the potential of your Windows laptop, Chromebook, tablet or other device with a USB-A, USB-C or Thunderbolt 3 port. It’s ideal for transmitting 1080p video and digital audio to multiple large displays, adding a thumb drive and other USB peripherals, powering and charging a PD Charging-compliant mobile device, and connecting to a Gigabit Ethernet network—all at the same time. Transmits Crystal-Clear Hi-Def Video and Digital Audio to Multiple HDMI Displays Two HDMI outputs support individual high-definition resolutions up to 2560 x 1440 at 50 Hz. By downloading and installing the proper DisplayLink drivers to your host device, you may connect two HDMI displays simultaneously. This allows you to display the image from the host computer on both monitors, extend your host desktop across both with different windows open on each, or combine all into one large display as a video wall. Maximum resolution when both video ports are connected at the same time is 1920 x 1080 (1080p) at 60 Hz. USB Hub Ports Connect Keyboards, Thumb Drives and Other Peripherals Three USB-A hub ports accept USB peripherals, such as flash drives, mice, keyboards and printers. All support fast USB 3.2 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with USB 2.0 and USB 1.1 devices. One port also supports 5V 1.5A (7.5W) of power dedicated to fast-charging your mobile device (and 2.4A for Apple devices). Note: Host must support USB OTG (On-the-Go). PD Charging Port Charges the Connected Notebook, Tablet or Other Device Connect your host device to the USB-C Power Delivery port, which supports PD 3.0 charging of connected PD Charging-compliant devices, such as laptops, Kindles, iPads and Android smartphones, up 1/5 1000 Eaton Boulevard Cleveland, OH 44122 United States to 20V 4.25A (85W). The included power supply, when plugged into an AC outlet, provides the charging power. Accesses a Wired Gigabit Ethernet Network The RJ45 port offers access to a Gigabit Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Connects Speakers, Microphone and Other Audio Equipment The 3.5 mm mini stereo jack is convenient for connecting speakers, headphones or a microphone to your workstation. You can listen to music or record the latest episode of your podcast. Anti-Theft Lock Protects the USB Docking Station When You Aren’t Around Connect a user-supplied computer/laptop security cable lock (not included) to this K-lock port to protect your source device against theft. Specifications OVERVIEW UPC Code 037332272034 Product Type Docking Station Technology Cat5/5e; Cat6; HDMI; Stereo Audio; USB 3.x Host Connector USB C (FEMALE) VIDEO Video Input USB C (FEMALE) Video Output DISPLAYPORT (FEMALE); HDMI (FEMALE) Number of Monitors Supported 2 Video Ports (2) DISPLAYPORT (FEMALE); (1) HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 1.4; HDCP 2.2; DisplayPort 1.2; DisplayPort 1.4 Resolutions Supported HDMI Dual:1920 x 1200 60HzHDMI Single: 2560 x 1440 50Hz Supported Resolutions 1280x720 (720p); 1920x1080 (1080p); 1920x1200 Max Supported Video Resolution Single: 2560 x 1400 @50Hz Dual: 1920 x 1080 @60Hz Extended Mode Yes Extended Mode Details 2x HDMI (1080p). This is in addition to a built in monitor in the laptop or source device. Mirror Mode Yes Mirror Mode Details 2x HDMI (1920 x 1200 60Hz incl. 1080p). This is in addition to a built in monitor in the laptop or source device. 3D Video Supported No AUDIO Audio Ports 3.5MM (FEMALE) Audio Ports Details Mini stereo jack supports headphones and microphone 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Specification 2.1 Channel Audio DATA Data Ports (3) USB A (FEMALE) Data Ports Details (3) USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT AC Power Adapter Plug(s) BS 1363 UK; CEE 7/16 Schuko AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 2A AC Power Adapter Output Specs (V / A) 20V / 5A AC Power Adapter Cord Length (ft.) 6 AC Power Adapter Cord Length (m) 1.83 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Source Type AC Adapter with detachable power cord DC Barrel Plug OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve Output Volt/Amp (from external power supply) 20V/5A USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green/Blue (Power/Active) CHARGING Total Charging Watts 100 Charging Ports / Amps (1) 1.5A PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Material of Construction PC+ABS Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0mm Cable Length (ft.) 3.28 Cable Length (m) 1.00 Unit Dimensions (hwd / in.) 1.330 x 3.740 x 3.740 Unit Packaging Type Box Unit Weight (lbs.) 0.4 Unit Weight (kg) 0.18 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 20% to 80% RH, Non-Condensing Power Provided to Connected Device(s) USB-C PD 3.0 Port: 20V/15V/9V/5V/4.25A (85W), (x2) USB3.0-A Ports: 5V/0.9A (4.5W), USB3.0-A BC1.2 Port: 5V/1.5A (7.5W) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Number of Ports 8 Ports 1 Side A - Connector 1 USB C (FEMALE) Side B - Connector 1 (2) HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 (3) USB A (FEMALE) Side B - Connector 4 3.5MM (FEMALE) FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Ethernet Support Yes Auto MDIX Support Yes Full Duplex Support Yes 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Suspend Mode Support Yes Remote Wakeup Support Yes Driver Required Yes Recommended Category Cable Cat6 STANDARDS & COMPLIANCE TAA Compliant Option N External Power Supply Certifications CE; GS; TUV; UL; cUL Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
U442-DOCK20BINT 价格&库存
很抱歉,暂时无法提供与“U442-DOCK20BINT”相匹配的价格&库存,您可以联系我们找货
