U442-DOCK21-B
U442-DOCK21-B
    TRIPPLITE
    USB-C DOCK, DUAL DISPLAY - 5K 60
U442-DOCK21-B 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Device Drivers ● A driver CD-ROM is no longer included with this product. The latest drivers for Windows, macOS, Android, Chrome OS and Ubuntu are available from the DisplayLink website. Please visit https://www.displaylink.com/downloads. Supports 5K @ 60 Hz on one DisplayPort monitor (when connected to both DP ports) ● USB-C Dock, Dual Display - 5K 60 Hz DP, 4K 60 Hz HDMI, USB 3.x (5Gbps), USB-A/C Hub, GbE, 85W PD Charging Extends/mirrors 4K @ 60 Hz across 2 DP, 2 HDMI or HDMI/DP monitors simultaneously ● Supports 20V 4.25A (85W) power output for fast-charging large-capacity mobile devices ● Connects you to a wired 10/100/1000 Ethernet network when no Wi-Fi is available ● USB-C and USB-A hub ports allow connection of flash drives and other peripherals MODEL NUMBER: U442-DOCK21-B Applications USB-C dock with DisplayLink technology and 14 ports lets you mirror or extend video from your laptop or PC across 2 monitors simultaneously. ● Extend or mirror your laptop or PC monitor on multiple displays to aid in multitasking and increase productivity ● Transfer data to and from a USB flash drive or external hard drive ● Access a wired Ethernet network in a location with no or spotty Wi-Fi ● Charge your notebook or laptop through the USB-C PD Charging port ● Connect a microphone/headset to record a podcast or listen to music Features USB-C Docking Station Turns Your Device’s USB or Thunderbolt 3/4 Port into 14 New PortsThis universal USB-C dock with PD Charging expands the potential of your Windows laptop, Chromebook, smartphone or PC’s USB-A, USB-C or Thunderbolt 3/4 port. Connect the docking station using the included USB-C cable, and add 14 ports to your device:(2) 4K HDMI(2) 4K DisplayPortRJ45 Gigabit Ethernet(4) USB 3.2 Gen 1USB 3.2 Gen 1 with 5V/1.5A (7.5W) Fast ChargingUSB-C PD ChargingUSB-C data(2) 3.5 mm stereo Transmits Crystal-Clear True 5K/4K Video and Digital Audio with 4:4:4 ColorThe HDMI and DisplayPort (DP) outputs support true 4K resolutions up to 4096 x 2160 at 60 Hz with 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. When both DP outputs are connected to one DP monitor, that monitor will support 5K video up to 5120 x 2880 at 60 Hz. DisplayLink Technology Allows Connection of Multiple DisplaysBy downloading and installing the proper DisplayLink drivers to your host device, you may connect two external displays simultaneously. This allows you to display the image from the host computer on both monitors, extend your host desktop across both with different windows open on each, or combine all into one large display as a video wall. Connect multiple monitors (dual 4K @ 60 Hz DP; dual 4K @ 60 Hz HDMI; or 4K @ 60 Hz DP and 4K @ 60 Hz HDMI) in Extended and Mirror modes. Note: Mac OS laptops or computers will only extend to one monitor. The others will be mirrored. USB Hub Ports Connect Keyboards, Thumb Drives and Other PeripheralsOne USB-C and five USBA ports accept USB peripherals, such as flash drives, mice, keyboards and printers. All support fast USB 3.2 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with USB 2.0 and USB 1.1 devices. One USB-A port also supports BC 1.2 charging with 5V 1.5A (7.5W) of power dedicated to fast1/6 System Requirements ● Source device with USB-A, USB-C or Thunderbolt 3/4 port and DisplayLink drivers installed ● Display devices with HDMI and/or DisplayPort input ● Any major operating system Package Includes ● U442-DOCK21-B USB-C Dock, Dual Display, Black ● USB-C cable, 1 m ● USB-C to USB-A adapter ● External power supply (Input: 100–240V, 50/60 Hz, 1.8A; Output: 20V 6.75A) ● C5 to NEMA 5-15P Adapter, 5 ft. ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States charging your mobile device. Note: Host must support USB OTG (On-the-Go). PD Charging Port Charges the Connected Notebook, Tablet or Other DeviceConnect your host device to the USB-C Power Delivery port, which supports PD 2.0 charging of connected PD Chargingcompliant devices, such as laptops, Kindles, iPads and Android smartphones, up to 20V 4.25A (85W). The included power supply, when plugged into an AC outlet, provides the charging power. Accesses a Wired Gigabit Ethernet NetworkThe RJ45 port offers access to a Gigabit Ethernet network when Wi-Fi is unavailable or when a wired connection offers faster speeds. Connect using a UTP cable (sold separately), and enjoy true 10/100/1000 Mbps Ethernet speeds for fast data transfers. Connects Speakers, Microphone and Other Audio EquipmentTwo 3.5 mm mini stereo jacks are convenient for connecting speakers, headphones and/or a microphone to your workstation. You can listen to music or record the latest episode of your podcast. Anti-Theft Lock Protects the Docking Station When You Aren’t AroundConnect a user-supplied computer/laptop security cable lock (not included) to this K-lock port to protect your source device against theft. Detachable USB-C Cable Connects in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3/4 port in either direction for an instant connection every time. A USB-C to USB-A adapter is included for connecting the docking station to your host device’s USB-A port. Specifications OVERVIEW UPC Code 037332253477 Product Type Docking Station Technology Cat5/5e; Cat6; DisplayPort; HDMI; USB 3.x Host Connector USB C (MALE) VIDEO Video Input USB C (FEMALE) Video Output DISPLAYPORT (FEMALE); HDMI (FEMALE) Number of Monitors Supported 2 Video Ports (2) DISPLAYPORT (FEMALE); (2) HDMI (FEMALE) Video Ports Details DisplayPort 1.2; HDMI 2.0 Resolutions Supported DisplayPort (Single): 4K 60Hz (4096 x 2160)DisplayPort (Dual): 5K 60Hz (5120 x 2880)HDMI (Dual & Single): 4K 60Hz (4096 x 2160) Supported Resolutions 1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K); 5120x2880 (5K) Max Supported Video Resolution Dual DP: 5120 x 2880@60Hz; Single DP: 4096 x 2160@60Hz; Dual/Single HDMI: 4096 x 2160@60Hz; DP/HDMI: 4096 x 2160@60Hz Extended Mode Yes Extended Mode Details 2x DisplayPort (5K 60Hz)2x HDMI (4K 60Hz )1x DisplayPort (4K 60Hz) + 1x HDMI (4K 60Hz) 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Mirror Mode Yes Mirror Mode Details 2x DisplayPort (5K 60Hz)2x HDMI (4K 60Hz )1x DisplayPort (4K 60Hz) + 1x HDMI (4K 60Hz) HDR Support No 3D Video Supported Yes AUDIO Audio Ports (2) 3.5MM (FEMALE) Audio Ports Details Separate 3.5 mm mini stereo jacks for speakers and microphone Audio Specification 2.1 Channel Surround Sound, TRRS DATA Data Ports (1) USB C (FEMALE); (5) USB A (FEMALE) Data Ports Details (1) USB-C - USB 3.2 Gen 1 (5 Gbps); (5) USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT AC Power Adapter Plug(s) NEMA 5-15P North America AC Power Adapter Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.8A AC Power Adapter Output Specs (V / A) 20V / 6.75A AC Power Adapter Cord Length (ft.) 5.25 AC Power Adapter Cord Length (m) 1.6 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 5 Input Cord Length (m) 1.52 Bus Powered No BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Source Type AC Adapter with detachable power cord AC Adapter Input: 100–240V, 50/60 Hz, 1.8A; Output: 20V, 6.75A DC Barrel Plug OD: 5.5 x 2.5 x 10mm, Positive Pin, Negative Sleeve 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Consumption (Watts) 15.00 Output Volt/Amp (from external power supply) 20V/6.75A USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 USER INTERFACE, ALERTS & CONTROLS LED Indicators Power (Blue), USB Connection (Green) CHARGING Number of Charging Ports 6 Total Charging Watts 100 Charging Port Type (5) USB A (FEMALE); USB C (FEMALE) Charging Ports USB-A: 5V 1.5A (7.5W); USB-C: 100W (20V 5A) Power Delivery (PD 2.0) Charging Ports Details (4) USB-A ports support 5V/0.9A (4.5W) charging(1) USB-A port supports 5V/1.5A (7.5W) charging and Apple Charging 5V/2.4A (12A)(1) USB-C port supports 5V/1.5A (7.5W) chargingCharge host with PD 2.0 charging (5/9/15V, 3A; 20V/4.25A) up to 85W Charging Ports / Amps (4) 0.9A; (2) 1.5A; 2.4A PHYSICAL Color Black Material of Construction Polycarbonate, ABS Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0mm Cable Length (ft.) 3.28 Cable Length (m) 1.00 Shipping Dimensions (hwd / in.) 9.65 x 5.71 x 3.54 Unit Dimensions (hwd / in.) 9.840 x 3.240 x 1.360 Unit Packaging Type Box Unit Weight (lbs.) 0.86 Unit Weight (kg) 0.39 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range -4° to 158°F (-20° to 70°C) Relative Humidity 20% to 80% RH, Non-Condensing Operating Humidity Range 20% to 80% RH, Non-Condensing 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Humidity Range 20% to 80% RH, Non-Condensing Power Provided to Connected Device(s) USB-C PD: 20V/4.25A (85W),USB3.0-A Ports: 5V/0.9A (4.5W), USB3.0-A Fast Charging Port: 5V/1.5A (7.5W); USB-C: 5V/1.5A (7.5W) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) CONNECTIONS Number of Ports 15 Ports 1 Ports Detail RJ45 port supports true 10/100/1000 Mbps (Gigabit) network speeds Dock Connectors USB-C, USB-C PD Charging, (4) USB-A 3.2 Gen1, USB-A 3.2 Gen1 BC 1.2, (2) DisplayPort, (2) HDMI, (2) 3.5mm, RJ45 Side A - Connector 1 USB C (FEMALE) Side B - Connector 1 (2) DISPLAYPORT (FEMALE); (2) HDMI (FEMALE) Side B - Connector 2 (5) USB A (FEMALE) Side B - Connector 3 RJ45 (FEMALE) Side B - Connector 4 (2) 3.5MM (FEMALE) Side B - Connector 5 USB C (FEMALE) FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 5 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Multi-Resolution Support Yes Ethernet Support Yes UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes Displayport Specification 1.2 Driver Required Yes Recommended Category Cable Cat6 Cables STANDARDS & COMPLIANCE TAA Compliant Option N External Power Supply Certifications CE; GS; UL; cUL 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
U442-DOCK21-B 价格&库存
很抱歉,暂时无法提供与“U442-DOCK21-B”相匹配的价格&库存,您可以联系我们找货
