U444-006-DP
U444-006-DP
    TRIPPLITE
    USB-C TO DISPLAYPORT CABLE, 4K 6
U444-006-DP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to DisplayPort Active Adapter Cable (M/M), 4K 60 Hz, 6 ft. (1.8 m) MODEL NUMBER: U444-006-DP Highlights ● Transmits video signals from sources supporting USB DisplayPort Alt Mode ● Delivers UHD picture quality at resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz ● Supports USB 3.1 Gen 1 speeds up to 5 Gbps to ensure fast data transfers ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● Easy installation with plug-andplay operation—no software required ● Note: This cable is unidirectional. Will only work from a USB-C port to DisplayPort Applications ● Play 4K video from your laptop, Chromebook or MacBook on a large-screen monitor ● Give a video presentation at a meeting, training session, conference or trade show ● Multitask in two or more applications on multiple displays ● Add a second monitor and make it your primary monitor ● Edit large documents on two different monitors USB-C to DisplayPort adapter connects your DP monitor to the USB-C or Thunderbolt 3 port on your Chromebook or MacBook. Features Connects a DisplayPort Display to Your USB-C or Thunderbolt 3 DeviceThis USB-C to DisplayPort 4K cable helps you transmit digital audio and 4K video from your tablet, laptop, Chromebook, MacBook, smartphone or PC to a DisplayPort-enabled monitor or projector. It’s ideal for giving video presentations in conference rooms and classrooms, editing multiple documents on a larger screen, or streaming video for digital signage in crystal-clear 4K. Supports USB DisplayPort Alternate Mode for Transmitting Audio/Video SignalsWith a source device that also supports USB DisplayPort Alt Mode, you can extend video from your primary display to another, duplicate the same video on both displays, or change the second display to your primary. Transmits Crystal-Clear 4K Video and Digital AudioThis six-foot cable supports Ultra High Definition (UHD) video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, 36-bit Deep Color (12 bits per channel) and per-lane transfer rates of 5.4 Gbps (HBR2), 2.7 Gbps (HBR) and 1.62 Gbps (RBR). It also supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps. The cable is backward compatible with non-4K displays, so you can use a 1080p monitor if one is available. Built-In USB-C Cable Connects in Either DirectionConnect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Premium Construction for Premium PerformanceFoil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI line noise that can distort or destroy data. Molded gold-plated connectors with corrosion-resistant gold-plated contacts provide maximum conductivity and minimize data loss. Integral strain relief reduces stress and helps the cable and connectors move freely without cracking. Ready to Use Right Out of the PackageThe plug-and-play USB-C to DisplayPort adapter requires no software, drivers or external power and works with both Windows and Mac operating systems. Just plug the USB-C end into your computer’s USB-C or Thunderbolt 3 port, and plug the DisplayPort end into the display’s input port for immediate satisfaction. The six-foot cable fits easily into a briefcase or laptop bag for connecting on the go. 3-Year Warranty and Environmentally Responsible DesignThe U444-006-DP comes with a 3-year 1/4 System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with DisplayPort input Package Includes ● U444-006-DP USB-C to DisplayPort Cable, 4K @ 60Hz, Thunderbolt 3, 6 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States warranty. It’s manufactured in compliance with strict RoHS specifications. Locking DP Connector Helps Prevent Accidental Disconnection and Expensive DowntimeHaving a cable come loose accidentally can mean costly and time-consuming signal loss. The locking DisplayPort connector helps you avoid such danger, protecting your audio/video transmission by maintaining a secure link without failure. The locking cable is also invaluable when moving equipment in a rack or removing equipment from tight areas, ensuring the cord always stays connected. Specifications OVERVIEW UPC Code 037332210388 Product Type Active Cable Technology DisplayPort Cable Type Active VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz HDR Support Yes INPUT Bus Powered Yes Product Length (in.) 72 Product Length (cm.) 182.88 Product Length (ft.) 6 Product Length (m.) 1.83 BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 0.60 PHYSICAL Color Black Material of Construction PVC, ABS Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Length (ft.) 6 Cable Length (m) 1.83 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Weight (lbs.) 0.40 Unit Dimensions (hwd / in.) 0.500 x 7.000 x 9.000 Unit Packaging Type Polybag Unit Weight (lbs.) 0.23 Unit Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) BTUs 2.1 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Connector Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) IP68 Rated No IP20 Rated No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No Displayport Specification 1.2 HDCP Specification 1.3 Driver Required No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-006-DP 价格&库存
很抱歉,暂时无法提供与“U444-006-DP”相匹配的价格&库存,您可以联系我们找货
