1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C to DisplayPort Bi-Directional Active
Adapter Cable (M/M), 4K 60 Hz, HDR, Locking DP
Connector, 6 ft. (1.8 m)
Highlights
Bi-directional cable allows male
ends to connect to either source
or display
Converts audio/video signals
from sources supporting USB
DisplayPort Alt Mode
Delivers Ultra HD picture quality
at resolutions up to 3840 x 2160
(4K x 2K) @ 60 Hz
Reversible USB-C plug
connects in either direction for
immediate no-fuss use
Locking DisplayPort connector
prevents cable from coming
loose accidentally
MODEL NUMBER: U444-006-DP-BD
Applications
Watch 4K video content from a
Blu-ray player, game console,
laptop or tablet on a 4K
television or projector
Connect a Chromebook or
MacBook to a conference
table’s A/V box to give a video
presentation on large screens
Attach a 4K monitor to your PC
to allow easier multitasking
Play online or PC video games
that display optimal graphics
Set up digital signage in an
office lobby or trade show booth
Bi-directional audio/video cable connects a USB-C/Thunderbolt 3 source device to a DisplayPort monitor
or vice versa.
Features
Bi-Directional USB-C/DisplayPort Cable Delivers UHD Video to a 4K Monitor
This USB Type-C to DisplayPort adapter (M/M) connects a 4K-enabled monitor, projector or television to
your desktop computer, tablet, laptop, notebook, MacBook, Chromebook or smartphone. Because the
cable is capable of transmitting data in either direction, you can connect a DisplayPort monitor to a USB-C
(or Thunderbolt 3) source device or a USB-C (or Thunderbolt 3) monitor to a DisplayPort source. No other
adapter or cable is needed to complete your 4K audio/video connection.
Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video Signals
By connecting the cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K
video and digital audio to a monitor, television or projector without installing special software drivers. The
U444-006-DP-BD is ideal for multitasking, presenting video at trade shows and conferences, editing
documents, playing online games and watching 4K movies on a larger screen.
Transmits Crystal-Clear 4K HDMI Video with HDR and 4:4:4 Color
The U444-006-DP-BD supports Ultra HD video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with
multi-channel digital audio. It’s compatible with DisplayPort 1.2 standards for carrying HDR (high dynamic
range) signals, which provides a wide range of vibrant colors with richer contrast, brighter whites and
deeper blacks. HDCP 2.2 compliance allows you to stream iTunes and Netflix content with no
complications. This adapter also supports 4:4:4 chroma subsampling for top-level PC gaming or using
your HDTV as a PC monitor.
Locking DP Connector Helps Prevent Accidental Disconnection and Expensive Downtime
Having a cable come loose accidentally can mean costly and time-consuming signal loss. The locking
DisplayPort connector helps you avoid such danger, protecting your audio/video transmission by
maintaining a secure link without failure. The locking cable is also invaluable when moving equipment in a
rack or removing equipment from tight areas, ensuring the cord always stays connected.
Reversible USB-C Connector Attaches in Either Direction
Unlike traditional USB cables that connect in only one direction, the reversible USB-C male connector
plugs into a USB-C or Thunderbolt 3 port in either direction for a fumble-free connection every time.
1/3
System Requirements
Source or display device with
Alternate Mode
DisplayPort input (DisplayPort
1.2 required to achieve 4K @ 60
Hz)
Package Includes
U444-006-DP-BD USB-C to
Adapter Cable, M/M, 6 ft. (1.8
m)
USB-C adapter, F/M
Cleveland, OH 44122
United States
Ready to Use Right from the Package, So You Can Plug and Play Immediately
The plug-and-play USB Type-C to DisplayPort bi-directional cable requires no software or external power.
The six-foot cable is backward compatible with previous USB and DisplayPort generations, so you can
use it with legacy equipment.
Specifications
OVERVIEW
UPC Code
037332250711
Product Type
Active Cable
Technology
DisplayPort
Cable Type
Active
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 60Hz
HDR Support
Yes
Chroma Sub Sampling
4:4:4
INPUT
Bus Powered
Yes
PHYSICAL
Color
Black
Material of Construction
PVC, ABS
Cable Jacket Color
Black
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.5mm
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (lbs.)
0.14
ENVIRONMENTAL
Operating Temperature Range
14° to 104°F (-10° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
2/3
Cleveland, OH 44122
United States
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
DISPLAYPORT (MALE)
Connector Plating
Gold
Contact Plating
Gold
FEATURES & SPECIFICATIONS
IP68 Rated
No
IP20 Rated
No
Displayport Specification
1.2
HDCP Specification
2.2
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U444-006-DP-BD”相匹配的价格&库存,您可以联系我们找货
