1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB-C to HDMI Adapter Cable (M/M), 4K 60 Hz,
4:4:4, Thunderbolt 3 Compatible, Black, 6 ft. (1.8
m)
Highlights
Converts audio/video signals
from sources supporting USB
DisplayPort Alt Mode
Supports UHD resolutions up to
4K @ 60 Hz (4:4:4) for crystalclear video
Reversible USB-C plug
connects in either direction for
immediate no-fuss use
Dual male plugs connect directly
to devices—no other adapter or
cable is needed
Unidirectional cable will only
work from a USB-C port to
HDMI port
MODEL NUMBER: U444-006-H4K6BE
Applications
Watch 4K video content from a
Blu-ray player, game console,
laptop or tablet on an Ultra HD
television, monitor or projector
Connect a Chromebook or
MacBook to a conference
table’s A/V box to give a video
presentation on a large screen
Play online or PC video games
that display optimal graphics
Attach an HDTV to your PC for
use as a 4K monitor
Connects your tablet, MacBook, Chromebook or smartphone’s USB-C or Thunderbolt 3 port to an HDMI
monitor or TV.
Features
USB-C to HDMI Adapter Connects to Your Computer’s USB-C or Thunderbolt 3 PortThis USB TypeC to HDMI adapter (M/M) connects an HDMI monitor, projector or television to the USB-C or Thunderbolt
3 port on your desktop computer, tablet, laptop, notebook, MacBook, Chromebook or smartphone. It’s an
ideal connector for multitasking, presenting video at trade shows and conferences, editing documents,
playing online games and watching movies on a larger 4K screen. No other adapter or cable is needed to
complete your 4K connection.
Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video SignalsBy connecting the
USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and
digital audio to an HDMI monitor, television or projector without installing special software drivers.
Enjoy the Clarity of True 4K HDMI Video with Multi-Channel Audio and 4:4:4 ColorThis 4K HDMI
cable supports Ultra HD video resolutions up to 4K x 2K (4096 x 2160) at 60 Hz for crystal-clear picture
and sound, as specified in HDMI 2.0. It’s compatible with HDCP 2.2 as well as backwards compatible with
HDCP 1.4. It also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a
PC monitor, as well as 36-bit Deep Color (12 bits per channel).
Reversible USB-C Connector Attaches in Either DirectionUnlike traditional USB cables that connect in
only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in
either direction for a fumble-free connection every time.
Ready to Use Right from the Package, So You Can Plug and Play ImmediatelyThe plug-and-play
USB Type-C to HDMI cable requires no software or external power. Just connect the USB-C plug to the
USB-C or Thunderbolt 3 port on a source device that supports USB DisplayPort Alternate Mode, and
connect the HDMI plug to your display. The six-foot USB 3.1 Gen 1 cable is backward compatible with
previous USB and HDMI generations, so you can use it with legacy equipment.
Specifications
1/3
System Requirements
Source device with USB-C or
Thunderbolt 3 port that supports
Mode
Display device with HDMI input
Package Includes
U444-006-H4K6BE USB-C to
HDMI Adapter, M/M, Black, 6 ft.
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332237101
Product Type
Passive Cable
Technology
HDMI
VIDEO
Max Supported Video Resolution
HDMI: 3840 x 2160, Including 4096 x 2160 (4K x 2K) @ 60Hz
Max Supported Color Depth
36-bit Deep Color
INPUT
Bus Powered
Yes
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
Power Consumption (Watts)
0.60
PHYSICAL
Color
Black
Material of Construction
PVC, ABS
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.2mm
Wire Gauge (AWG)
34/32/26
Cable Length (ft.)
6
Cable Length (m)
1.83
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.00
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 22.86
Shipping Weight (lbs.)
0.18
Shipping Weight (kg)
0.08
Unit Weight (lbs.)
0.22
Unit Weight (kg)
0.10
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
2/3
Cleveland, OH 44122
United States
Storage Temperature Range
14° to 158°F (-10° to 70°C)
BTUs
2.1 BTU/Hr
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
IP68 Rated
No
IP20 Rated
No
HDCP Specification
1.4; 2.2
Driver Required
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U444-006-H4K6BE”相匹配的价格&库存,您可以联系我们找货
