U444-009-H4K6BE
U444-009-H4K6BE
    TRIPPLITE
    缆线组件 USB C 公插头转 HDMI-A 公头 9.00'(2.74m)
U444-009-H4K6BE 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to HDMI Adapter Cable (M/M), 4K 60 Hz, 4:4:4, Thunderbolt 3 Compatible, Black, 9 ft. (2.7 m) Highlights ● Converts audio/video signals from sources supporting USB DisplayPort Alt Mode ● Supports UHD resolutions up to true 4K @ 60 Hz (4:4:4) for crystal-clear video ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● Uni-directional cable only transmits A/V signals from a USB-C port to HDMI port MODEL NUMBER: U444-009-H4K6BE Applications USB-C to HDMI cable directly connects an HDMI monitor to your tablet, MacBook, Chromebook or smartphone’s USB-C or Thunderbolt 3 port. ● Watch 4K video content from a Blu-ray player, game console, laptop or tablet on an Ultra HD television, monitor or projector ● Connect a Chromebook or MacBook to a conference table’s A/V box to give a video presentation on a large screen ● Play online or PC video games that display optimal graphics ● Attach an HDTV to your PC for use as a 4K monitor Features USB-C to HDMI Adapter Connects to Your Computer’s USB-C or Thunderbolt 3 Port This USB Type-C to HDMI adapter (M/M) connects an HDMI monitor, projector or television to the USB-C or Thunderbolt 3 port on your desktop computer, tablet, laptop, notebook, MacBook, Chromebook or smartphone. It’s an ideal connector for multitasking, presenting video at trade shows and conferences, editing documents, playing online games and watching movies on a larger 4K screen. No other adapter or cable is needed to complete your 4K connection. Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video Signals By connecting the USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to an HDMI monitor, television or projector without installing special software drivers. Enjoy the Clarity of True 4K HDMI Video with Multi-Channel Audio and 4:4:4 Color This 4K HDMI cable supports Ultra HD video resolutions up to 4K x 2K (4096 x 2160) at 60 Hz for crystalclear picture and sound, as specified in HDMI 2.0. It’s compatible with HDCP 2.2 as well as backwards compatible with HDCP 1.4. It also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor, as well as 36-bit Deep Color (12 bits per channel). Reversible USB-C Connector Attaches in Either Direction Unlike traditional USB cables that connect in only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in either direction for a fumble-free connection every time. Ready to Use Right from the Package, So You Can Plug and Play Immediately The plug-and-play USB Type-C to HDMI cable requires no software or external power. Just connect the USB-C plug to the USB-C or Thunderbolt 3 port on a source device that supports USB DisplayPort Alternate Mode, and connect the HDMI plug to your display. The nine-foot USB 3.1 Gen 1 cable is backward compatible with previous USB generations, so you can use it with legacy equipment. Specifications OVERVIEW UPC Code 037332237118 1/3 System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode ● Display device with HDMI input Package Includes ● U444-009-H4K6BE USB-C to HDMI Adapter, M/M, Black, 9 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Passive Cable Technology HDMI VIDEO Max Supported Video Resolution HDMI: 3840 x 2160, Including 4096 x 2160 (4K x 2K) @ 60Hz Max Supported Color Depth 36-bit Deep Color INPUT Bus Powered Yes BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 0.6 PHYSICAL Color Black Material of Construction PVC, ABS Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.2mm Wire Gauge (AWG) 34/32/26 Cable Length (ft.) 9 Cable Length (m) 2.74 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 Unit Weight (lbs.) 0.22 Unit Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) BTUs 2.1 BTU/Hr 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) IP68 Rated No IP20 Rated No HDCP Specification 1.4; 2.2 Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U444-009-H4K6BE 价格&库存
很抱歉,暂时无法提供与“U444-009-H4K6BE”相匹配的价格&库存,您可以联系我们找货
