U444-06N-H4UBC2
U444-06N-H4UBC2
    TRIPPLITE
    USB-C MULTIPORT ADAPTER - HDMI 4
U444-06N-H4UBC2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Multiport Adapter - HDMI 4K 60 Hz, 4:4:4, HDR, USB 3.x (5Gbps) Hub Ports, 100W PD Charging, Black Highlights ● Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) for crystalclear video ● Converts audio/video signals from sources supporting USB DisplayPort Alt Mode ● USB-C PD 3.0 port provides 20V 5A (100W) power output for charging connected device ● USB-A port supports USB 3.1 Gen 1 speeds up to 5 Gbps for fast data transfers ● Supports High Dynamic Range (HDR) for richer contrast and expanded color accuracy MODEL NUMBER: U444-06N-H4UBC2 Applications ● Watch 4K video content from a Blu-ray player, game console, laptop or tablet on an Ultra HD television or projector ● Connect a Chromebook or MacBook to a conference table’s A/V box to give a video presentation on a large screen ● Edit HDR video or digital photos using a 4K monitor ● Charge and power a USB-C or Thunderbolt 3 device with its AC wall charger ● Connect a USB peripheral, such as an external hard drive, printer or hub 4K USB-C adapter adds HDMI, USB-A and USB-C PD charging ports to the USB-C or Thunderbolt 3 port on your MacBook or Chromebook. Features USB-C Adapter Turns Your USB-C or Thunderbolt 3 Device into a Multiport WorkstationThis 4K adapter turns the USB-C or Thunderbolt 3 port on your tablet, laptop, Chromebook, MacBook, smartphone or PC into multiple ports. It’s ideal for transmitting digital audio and 4K video to a large display, adding a thumb drive or other USB peripheral, and powering and charging a PD Chargingcompliant mobile device—all at the same time. It’s an ideal tool for working in high-definition photography, videography or cinematography, as well as streaming video for digital signage in crystal-clear 4K. Supports USB DisplayPort Alternate Mode for Converting Audio/Video SignalsBy connecting the built-in USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to an HDMI monitor, television or projector without installing special software drivers. Transmits Crystal-Clear 4K HDMI Video with HDR and 4:4:4 ColorThe U444-06N-H4UBC2 supports Ultra HD video resolutions up to 4K x 2K (4096 x 2160) at 60 Hz, as specified in HDMI 2.0. It is capable of carrying HDR signals, which provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks. HDCP 2.2 compliance allows you to stream iTunes and Netflix content with no complications. This adapter supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Connects USB Peripherals and Transfers Data at Fast USB 3.1 Gen 1 SpeedsThe USB-A port accepts USB peripherals, such as a flash drive, mouse, keyboard or printer, and supports charging up to 5V 1.5A (7.5W) for mobile devices. It transfers data at speeds up to 5 Gbps, which is 10 times faster than USB 2.0. Note: Host must support USB OTG (On-the-Go). PD 3.0 Charging Port Charges High-Powered Devices via AC Wall ChargerThe USB-C Power Delivery port provides power output up to 20V 5A (100W), which is more than sufficient for charging and powering the connected source device, such as a MacBook or Chromebook. Connect the port to the device’s AC wall charger. Like the USB-A port, the USB-C port also transfers data at USB 3.1 Gen 1 speeds up to 5 Gbps. Note: USB-C PD port does not support Quick Charge (QC). Built-In USB-C Cable Attaches in Either DirectionUnlike traditional USB cables that connect in only 1/4 System Requirements ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode (DP 1.4 required for 4K @ 60 Hz) ● Display device with HDMI input Package Includes ● U444-06N-H4UBC2 USB-C Multiport Adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in either direction for a fumble-free connection every time. Ready to Use Right Out of the PackageThe plug-and-play USB 3.1 Type-C adapter is specifically designed for the MacBook, Google Chromebook Pixel and other laptops, tablets and devices equipped with a USB-C or Thunderbolt 3 port. It requires no software, drivers or external power. About the size of a credit card, the U444-06N-H4UBC2 fits easily into a pocket, purse or laptop bag for convenient connections on the go. Specifications OVERVIEW UPC Code 037332251282 Product Type Multiport Adapter Technology HDMI; USB 3.x Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 2.2 Resolutions Supported HDMI: 4K 60Hz (4096 x 2160) Supported Resolutions 1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K) Max Supported Video Resolution 4096 x 2160 @ 60 Hz (with DP1.4 enabled host); 4096 x 2160 @ 30 Hz (with DP1.2 enabled host) Extended Mode Yes Extended Mode Details Extends a 4K video resolution to a connected HDMI display Mirror Mode Yes Mirror Mode Details Mirror a desktop to a connected 4K display Max Supported Color Depth 8-bit HDR Support Yes 3D Video Supported No Chroma Sub Sampling 4:4:4 AUDIO Audio Specification Stereo DATA 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Data Ports USB A (FEMALE); USB C (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps); USB-C - USB 3.2 Gen 1 (5 Gbps) INPUT Built-In Cable Length (in.) 6 Built-In Cable Length (cm) 15.24 Bus Powered Yes BATTERY Battery Charging (5V/1.5A Port) No POWER USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 3.0 CHARGING Number of Charging Ports 2 Total Charging Amps 5 Total Charging Watts 100 Charging Port Type USB A (FEMALE); USB C (FEMALE) Charging Ports USB-C: 100W (20V 5A) Power Delivery (PD 3.0); USB-A: 5V 1.5A (7.5W) Charging Ports Details Provides up to 100W (20V/5A) of power to the host device via the PD Charging portCharge a peripheral device with up to 7.5W (5V/1.5A) of power via the USB-A port Charging Ports / Amps (1) 2.4A; (1) 5A PHYSICAL Color Black Material of Construction PVC, ABS, Aluminum Cable Jacket Material TPE Cable Jacket Rating VW-1 Wire Gauge (AWG) 34 AWG, 24 AWG Wire Gauge (OD - mm²) 4.2 Unit Dimensions (hwd / in.) 0.450 x 1.340 x 2.830 Unit Dimensions (hwd / cm) 1.15 x 3.4 x 7.185 Unit Packaging Type Box Unit Weight (lbs.) 0.0661 Unit Weight (kg) 0.03 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85% RH Storage Humidity Range 5% to 90% RH Power Provided to Connected Device(s) USB-A Port = Max 7.5W (5V/1.5A); PD Charge 3.0 Port = Max 100W (20V/5A), with 7.5W dedicated to the unit and remaining 92.5W passed to the host device CONNECTIONS Number of Ports 3 Side A - Connector 1 USB C (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB A (FEMALE) Side B - Connector 3 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 2 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) HDCP Specification 2.2 Driver Required No STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-06N-H4UBC2 价格&库存
很抱歉,暂时无法提供与“U444-06N-H4UBC2”相匹配的价格&库存,您可以联系我们找货
