U444-06N-HD8K6W
U444-06N-HD8K6W
    TRIPPLITE
    USB-C TO HDMI ADAPTER (M/F) - 8K
U444-06N-HD8K6W 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to HDMI Adapter (M/F) - 8K 60 Hz, HDR, 4:4:4, HDCP 2.3, White MODEL NUMBER: U444-06N-HD8K6W Highlights ● Supports UHD resolutions up to 8K @ 60 Hz for heightened video quality ● Converts audio/video signals from sources supporting USB DisplayPort Alt Mode ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Complies with HDCP 2.3 standards to display up-to-date 8K video content ● Plug-and-play operation with no software required for easy, immediate installation System Requirements USB-C to HDMI cable connects an 8K HDMI display to your MacBook Pro, Windows laptop or tablet’s USB-C or Thunderbolt port. Features USB-C to HDMI Converter Connects a USB-C or Thunderbolt Port to an 8K Monitor This USB Type-C to HDMI adapter (M/F) connects to an 8K-capable HDMI cable to add an HDMI monitor, projector or television to the USB-C, Thunderbolt 3 or Thunderbolt 4 port on your MacBook Pro or Windows laptop. It’s an ideal connector for Ultra HD video applications, including editing professional video or digital artwork, upgrading your trade show or conference presentations, playing online games or watching movies on a larger 8K screen. Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video Signals By connecting the USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 8K video and digital audio to an HDMI monitor, television or projector without installing special software drivers. Transmits Crystal-Clear 8K Video with HDR and 4:4:4 Color The U444-06N-HD8K6W supports 8K video resolutions up to 7680 x 4320 at 60 Hz, as well as HDR video, providing a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 8K display. HDCP 2.3 compliance allows you to stream Amazon and Netflix content with no complications. This adapter also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Ready to Use Right from the Package, So You Can Plug and Play Immediately The plug-and-play USB Type-C to HDMI adapter requires no software or external power. Just connect the USB-C plug to the USB-C, Thunderbolt 3 or Thunderbolt 4 port on a source device that supports USB DisplayPort Alternate Mode, and connect the HDMI port to your 8K display using an 8K-capable HDMI cable (sold separately). This adapter is backward compatible with 1080p and 4K displays, allowing you to use it with older equipment. Specifications OVERVIEW 1/4 ● Source device with USB-C, Thunderbolt 3 or Thunderbolt 4 port that supports USB DisplayPort Alternate Mode ● Display device with HDMI input ● HDMI cable (M/M) that supports 8K 60 Hz resolutions ● All connected devices and cables must support 8K to achieve 8K resolutions Package Includes ● U444-06N-HD8K6W USB-C to HDMI 8K Adapter - M/F, White ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332272638 Product Type Multiport Adapter Technology HDMI; Thunderbolt; USB 3.x Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 1 Video Ports HDMI (FEMALE) Video Ports Details HDMI 2.0; DisplayPort 1.4; HDCP 2.3 Supported Resolutions 1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K); 5120x2880 (5K); 7680x4320 (8K) Max Supported Video Resolution 7680 x 4320 (8K) @ 60Hz Extended Mode Yes Extended Mode Details Extend a desktop to a connected HDMI monitor at resolutions up to 7680 X 4320 @ 60 Hz Mirror Mode Yes Mirror Mode Details Mirror the image from the host computer to a connected display at resolutions up to 7680 X 4320 @ 60 Hz. Max Supported Color Depth 36-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2; 4:4:4 EDID Support Yes Signal Transmission Unidirectional DisplayPort Alt Mode Yes DSC Support Yes AUDIO Audio Ports HDMI (FEMALE) Audio Ports Details Supports 1 to 32 channels LPCM 192kHz audio outputSupports HBR audio up to 1536kHz Audio Specification Supports 1 to 32 channels LPCM 192kHz audio output and HBR audio up to 1536kHz INPUT Built-In Cable Length (ft.) 0.5 Built-In Cable Length (in.) 6 Bus Powered Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Battery Charging (5V/1.5A Port) No PHYSICAL Color White Material of Construction ABS + PVC Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating FT2 Cable Outer Diameter (OD) 3.9MM Wire Gauge (AWG) 34/28 Cable Length (ft.) 0.393 Cable Length (m) 0.12 Cable Length (in.) 4.72 Shipping Dimensions (hwd / in.) 0.80 x 4.70 x 3.90 Shipping Weight (lbs.) 0.07 Unit Dimensions (hwd / in.) 0.600 x 1.460 x 1.650 Unit Dimensions (hwd / cm) 1.55 x 3.7 x 4.19 Unit Dimensions (hwd / mm) 15.5 x 37 x 41.9 Unit Packaging Type Box Unit Weight (lbs.) 0.070 Unit Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Relative Humidity 10% to 90% RH Operating Humidity Range 10% to 90% RH Storage Humidity Range 10% to 90% RH COMMUNICATIONS EDID Compatible Yes CONNECTIONS Number of Ports 1 Side A - Connector 1 USB C (MALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 1 HDMI (FEMALE) Connector Plating Nickel Contact Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.2 Gen 1 (up to 5 Gbps) MST Support Yes Multi-Resolution Support Yes UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No Displayport Specification 1.2; 1.4 HDCP Specification 2.3 Driver Required No Pixel Size RGB/YCbCr4:4:4/YCbCr4:2:2/YCbCr4:2:0 STANDARDS & COMPLIANCE Product Certifications EN 55024; EN 55032 Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-06N-HD8K6W 价格&库存
很抱歉,暂时无法提供与“U444-06N-HD8K6W”相匹配的价格&库存,您可以联系我们找货
U444-06N-HD8K6W
    库存:1
