U444-2H-MST4K6
U444-2H-MST4K6
    TRIPPLITE
    USB-C ADAPTER, DUAL DISPLAY - 4K
U444-2H-MST4K6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C Adapter, Dual Display - 4K 60 Hz HDMI, HDR, 4:4:4, HDCP 2.2, DP 1.4 Alt Mode, Black MODEL NUMBER: U444-2H-MST4K6 Highlights ● Converts audio/video signals from sources supporting USB-C DisplayPort Alt Mode ● Plays 4K video on 2 displays simultaneously for multitasking and increasing productivity ● Supports UHD resolutions up to 4K @ 60 Hz (4:4:4) with 7.1channel surround sound ● Carries High Dynamic Range (HDR) signals for rich contrast and expanded color accuracy ● Plug-and-play operation with no software required for easy, immediate installation System Requirements USB-C to HDMI adapter connects dual HDMI 4K displays to the USB-C or Thunderbolt 3 port on your MacBook Pro or Windows laptop. Features USB-C to HDMI Adapter Connects Two 4K HDMI Displays to Your USB-C Device This USB adapter connects two independent HDMI monitors, projectors and/or televisions to the USB-C or Thunderbolt 3 port on your MacBook Pro, Chromebook or Windows laptop. It’s an ideal connector for creating video walls, giving video presentations in conference rooms and classrooms, editing multiple documents on a larger screen, or streaming video for digital signage in crystal-clear 4K. Supports USB-C DisplayPort Alternate Mode for Converting Audio/Video Signals By connecting the built-in USB-C cable to a source device that supports USB DisplayPort Alt Mode, you can output 4K video and digital audio to HDMI monitors, televisions or projectors without installing special software drivers. Note: To achieve 4K resolution, the source device should support DP 1.4 Alt Mode. When a monitor is connected to a DP 1.2 Alt Mode source, the corresponding resolution will be decreased due to bandwidth limitation. DisplayPort SST and MST Modes Allow Connection of Multiple Displays By connecting the USB-C adapter to a source that supports DisplayPort Single-Stream Transport (SST) or Multi-Stream Transport (MST) mode, you may connect up to two displays simultaneously. This allows you to display the same image on both monitors, extend your host desktop across both with different windows open on each, or combine both into one large display as a video wall, depending on your operating system. Enjoy the Clarity of 4K Video with HDR, 4:4:4 Color and 7.1-Channel Audio This USB to HDMI adapter supports Ultra HD video resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz with 36-bit Deep Color and 7.1-channel surround sound. High Dynamic Range (HDR) provides a wide range of vibrant colors with richer contrast, brighter whites and deeper blacks that pop on your 4K display. HDCP 2.2 compliance allows you to stream 4K Amazon and Netflix content with no complications. This adapter also supports 4:4:4 chroma subsampling for top-level PC gaming or using your HDTV as a PC monitor. Ready to Use Right from the Package, So You Can Plug and Play Immediately The adapter requires no software or external power. Just connect the USB-C cable to the USB-C or Thunderbolt 3 port on a source device that supports USB DisplayPort Alternate Mode, and connect the HDMI ports to your displays with user-provided cables (such as P568-XXX-2A Series cables). 1/4 ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode (DP 1.4 Alt Mode required for some features) ● Display device(s) with HDMI input ● Multi-Stream Transport (MST) required to achieve extended dual displays; typically, Windows systems support MST ● Single-Stream Transport (SST) required to achieve mirrored dual displays; typically, Mac systems support SST Package Includes ● U444-2H-MST4K6 USB-C Adapter, Dual Display, Black ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332263773 Product Type USB-C to HDMI Multi-Port Adapter Device Compatibility Chromebook; Laptop; Monitor/HDTV; Projector Technology HDMI; USB 3.x Host Connector USB C (MALE) VIDEO Video Input USB C (MALE) Video Output HDMI (FEMALE) Number of Monitors Supported 2 Video Ports (2) HDMI (FEMALE) Video Ports Details HDMI 2.0; HDCP 2.2; DisplayPort 1.4 Resolutions Supported When used with a DP 1.4 host device the product supports dual output 4K (3840 x 2160) @ 60 Hz maximumWhen used wiht a DP 1.2a host device the product supports dual output 4K (3840 x 2160) @ 30 Hz maximum Supported Resolutions 1280x720 (720p); 1920x1080 (1080p); 3840x2160 (4K) Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz Recommended Cabling P569-Series HDMI Cabling Extended Mode Yes Extended Mode Details x2 HDMI ports support dual output 4K/60 Hz videoWhen used on a Windows PC the device supports MST Mode to transmit different videos/picturesWhen used on a Mac the device supports SST mode to transmit mirror mode only Mirror Mode Yes Mirror Mode Details x2 HDMI ports support dual output 4K/60 Hz videoWhen used on a Windows PC the device supports MST Mode to transmit different videos/picturesWhen used on a Mac the device supports SST mode to transmit mirror mode only Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:0; 4:4:4 AUDIO Audio Ports (2) HDMI (FEMALE) Audio Ports Details Supports pass-through audio function via dual HDMI outputs Audio Input USB-C Audio Output HDMI 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Specification 7.1 Channel Surround Sound INPUT Built-In Cable Length (ft.) 0.394 Built-In Cable Length (m) 0.12 Built-In Cable Length (in.) 4.72 Built-In Cable Length (cm) 12 Bus Powered Yes BATTERY Battery Charging (5V/1.5A Port) No POWER USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators N/A PHYSICAL Color Black Material of Construction TPE Cable Jacket Color Black Cable Jacket Material TPE Cable Outer Diameter (OD) 4.3mm Wire Gauge (AWG) 24 + 32 + 34 Number of Displays 2 Shipping Dimensions (hwd / in.) 0.79 x 4.72 x 3.94 Shipping Weight (lbs.) 0.11 Unit Dimensions (hwd / in.) 0.450 x 2.170 x 1.970 Unit Dimensions (hwd / cm) 1.15 x 5.51 x 5 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 10% to 85% RH, Non Condensing Storage Humidity Range 5% to 90% RH, Non Condensing CONNECTIONS Number of Ports 2 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (2) HDMI (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.2 Gen 2 (Up to 10 Gbps) MST Support Yes Multi-Resolution Support Yes Displayport Specification 1.4 HDCP Specification 2.2 Driver Required No STANDARDS & COMPLIANCE Product Certifications EN 55032; EN 55035; IEC/EN 63000 Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U444-2H-MST4K6 价格&库存
很抱歉,暂时无法提供与“U444-2H-MST4K6”相匹配的价格&库存,您可以联系我们找货
