U457-025-AG2
U457-025-AG2
    TRIPPLITE
    USB 3.1 GEN 1 5 GBPS SATA SSD/HD
U457-025-AG2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.1 Gen 1 (5 Gbps) 2.5 in. SATA SSD/HDD to USB-A Enclosure Adapter with UASP Support MODEL NUMBER: U457-025-AG2 Highlights ● Compatible with 2.5 in. SATA SSDs and HDDs up to 2 TB ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Works up to 70% faster when connected to UASP host controller ● Durable slim design perfectly sized for backpack or laptop bag ● Plug-and-play—no software, drivers or external power supply System Requirements ● Computer with USB port (USB 3.1 Gen 1 port required for maximum speed) ● 2.5 in. SATA SSD or HDD (9.5 mm max height) Package Includes Durable lightweight enclosure connects a 2.5 in. SATA SSD or HDD to your computer’s USB-A port and performs fast file transfers at USB 3.1 Gen 1 speeds. UASP-enabled for 70% more speed with UASP host controller. ● U457-025-AG2 USB 3.1 Gen 1 SATA SSD/HDD to USB-A Enclosure Adapter ● USB 3.1 Gen 1 Micro-B to USBA cable, 2 ft. ● Mini screwdriver ● (2) Screws ● Storage sleeve ● Owner’s manual Description The U457-025-AG2 USB 3.1 Gen 1 (5 Gbps) SATA SSD/HDD to USB-A Enclosure Adapter lets you connect a high-performance SATA solid state drive (SSD) or hard disk drive (HDD) to a computer or laptop with a USB-A port. Not only does it support USB 3.1 Gen 1 data transfer rates up to 5 Gbps, but it reads data up to 70 percent faster and writes up to 40 percent faster when connected to a UASP-enabled host controller. Recommended for storing and sharing large files, such as photos, music and video files, the U457-025AG2 accepts 2.5-inch SATA drives up to 2 TB. You can access data on an older SATA drive, or use a new SATA drive for additional storage space. The adapter is plug-and-play, so no software, drivers or external power supply is required, and it is backward compatible with previous USB generations. A blue LED indicates data is being read, written or transferred. Slim aluminum case stores conveniently in a backpack or laptop bag for use anywhere. Features Connects an Internal SATA Drive to Your Computer’s USB-A Port ● Recommended for storing and sharing large photo, music and video files ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Features UASP for performance up to 70% faster when connected to UASP-enabled host controller ● Compatible with all USB-enabled operating systems Compatible with 2.5 in. SATA Drives Up to 2 TB ● Accepts SATA III, II and I SSDs and HDDs ● Will support higher-capacity drives when available ● Backward compatible with previous USB generations ● Blue LED indicates drive data is being read, written or transferred Designed for Immediate Use ● Plug and play—no software, drivers or external power supply needed 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Durable slim aluminum case perfectly sized for backpack or laptop bag ● Enclosed housing protects drive in applications requiring more durability ● USB 3.1 Gen 1 cable included Specifications OVERVIEW UPC Code 037332202437 Drives Supported 2.5" HDD and SSD Technology SATA/eSATA INPUT Bus Powered Yes POWER Power Consumption (Watts) 5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Read, Write, Power) PHYSICAL Color Black Material of Construction Aluminum Shipping Dimensions (hwd / in.) 1.89 x 7.13 x 5.04 Shipping Dimensions (hwd / cm) 4.80 x 18.11 x 12.80 Shipping Weight (lbs.) 0.14 Shipping Weight (kg) 0.06 Unit Dimensions (hwd / in.) 0.512 x 5.079 x 2.953 Unit Dimensions (hwd / cm) 1.3 x 12.9 x 7.5 Unit Packaging Type Box Unit Weight (lbs.) 0.14 Unit Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range 50° to 122°F (10° to 50°C) Storage Temperature Range 32° to 149°F (0° to 65°C) Relative Humidity 10% to 80% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States BTUs 17.1 BTU/Hr CONNECTIONS Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel Contact Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) IP68 Rated No IP20 Rated No UASP Support Yes Driver Required No STANDARDS & COMPLIANCE Product Certifications UL Listed Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U457-025-AG2 价格&库存
很抱歉,暂时无法提供与“U457-025-AG2”相匹配的价格&库存,您可以联系我们找货
