U457-025-G2-WPB
U457-025-G2-WPB
    TRIPPLITE
    USB-C TO SATA SSD/HDD ENCLOSURE
U457-025-G2-WPB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-C to SATA SSD/HDD Enclosure Adapter USB 3.1 Gen 2 (10 Gbps), Thunderbolt 3, IP66 Rated, UASP Highlights ● Connects 2.5 in. SATA SSDs and HDDs up to 2 TB to your computer, tablet or laptop ● Dustproof, shockproof and IP66rated to endure powerful jets of water from any direction ● Supports USB 3.1 Gen 2 speeds up to 10 Gbps to ensure lightning-fast data transfers ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● Plug-and-play operation with no software required for easy, immediate installation MODEL NUMBER: U457-025-G2-WPB Applications ● Create a portable solution for on-the-go file backups and data storage ● Retrieve data from old SATA drives up to 2 TB ● Utilize UASP for high-speed read/write Creates portable external storage for SATA drives via the USB-C or Thunderbolt 3 port on your tablet, MacBook or Chromebook. System Requirements Features Connect a High-Performance SATA Drive to Your Computer’s USB-C or Thunderbolt 3 PortThis SATA enclosure is idea for adding external storage space when your laptop’s hard drive has no more room for your photos, videos, music and documents. The U457-025-G2-WPB lets you connect a SATA solid state drive (SSD) or hard disk drive (HDD) to any device with a USB-C or Thunderbolt 3 port, including a MacBook, Ultrabook, Chromebook, notebook, tablet or PC. It also helps you retrieve data stashed on old 2.5-inch SATA III, II and I drives up to 2 TB. It will also support higher SATA capacities as they become available. Transfers Data at Fast USB 3.1 Gen 2 Speeds with UASP SupportThis adapter supports USB 3.1 Gen 2 data transfer rates up to 10 Gbps, which is twice the speed of USB 3.1 Gen 1, to give you more data storage, retrieval and backup capacity. A blue LED indicates when drive data is being read, written or transferred. The U457-025-G2-WPB reads data up to 70 percent faster and writes up to 40 percent faster when connected to a UASP-enabled host controller. It is also backward compatible with previous USB generations, allowing you to use it with older equipment. IP66 Rating Denotes Resistance to Dust and WaterThe IP66 rating means the SATA enclosure is not only 100% protected against dust, but also able to endure high-pressure jets of water from any direction with no damage or decline in performance. In addition to its water and dust resistance, the U457-025-G2WPB is shockproof, giving you peace of mind without worrying about dropping and damaging the unit. Built-In USB-C Cable Attaches in Either DirectionUnlike traditional USB cables that connect in only one direction, the reversible USB-C male connector plugs into a USB-C or Thunderbolt 3 port in either direction for a fumble-free connection every time. The seven-inch wraparound cable stores within the adapter, ensuring it will never become lost. Just Plug and Play for Immediate Use Right Out of the PackageNo software, drivers or external power supply is required. The U457-025-G2-WPB is compatible with all USB-enabled operating systems, including Windows, Mac and Linux. Its dustproof, shockproof, IP66-rated case fits easily into your laptop bag, backpack or briefcase, so you can take it with you wherever you go. 1/3 ● Device with a USB-C or Thunderbolt 3 port (USB 3.1 Gen 2 compatibility required to achieve USB 3.1 Gen 2 speeds) ● 2.5 in. SATA III, II or I drive with maximum height of 9.5 mm ● UASP-enabled host controller required to achieve UASP performance ● Compatible with all USBenabled operating systems Package Includes ● U457-025-G2-WPB USB-C to SATA SSD/HDD Enclosure Adapter ● Mini screwdriver ● (10) Screws ● (10) Washers ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332250513 Technology SATA/eSATA INPUT Built-In Cable Length (in.) 7.28 Built-In Cable Length (cm) 18.5 Bus Powered Yes USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power/Data) PHYSICAL Color Black Material of Construction ABS Unit Dimensions (hwd / in.) 0.890 x 5.790 x 3.700 Unit Packaging Type Box Unit Weight (lbs.) 0.5000 Unit Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 50° to 122°F (10° to 50°C) Storage Temperature Range 32° to 149°F (0° to 65°C) Relative Humidity 10% to 80% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.1 Gen 2 (up to 10 Gbps) IP68 Rated No IP20 Rated No UASP Support Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States SATA Version SATA I (1.5 Gbps); SATA II (3 Gbps); SATA III (6 Gbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U457-025-G2-WPB 价格&库存
很抱歉,暂时无法提供与“U457-025-G2-WPB”相匹配的价格&库存,您可以联系我们找货
