U460-004-4AB
U460-004-4AB
    TRIPPLITE
    4-PORT USB 3.1 HUB, 4X USB-A, TH
U460-004-4AB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB-C Hub, USB 3.x (5Gbps), 4x USB-A Ports, Black MODEL NUMBER: U460-004-4AB Highlights ● Supports USB 3.1 Gen 1 for fast data transfers up to 5 Gbps ● Accepts up to 4 USB peripherals, turning your laptop into a mini workstation ● Reversible USB-C plug connects in either direction for immediate no-fuss use ● USB ports provide up to 5V/1.5A (7.5W) for charging smartphones and other devices ● Easy installation with plug-andplay operation—no software required Applications USB 3.1 Type-C hub adds 4 USB-A ports to your laptop, MacBook, Chromebook or other compatible device. ● Transfer files to and from a USB thumb drive or external hard drive ● Connect your smartphone or other mobile device to build up a full charge ● Attach a USB headset/microphone for recording your podcast ● Write a report using a USB keyboard with your tablet or Android smartphone Features USB 3.1 Type-C Hub Connects to Your Device’s USB-C or Thunderbolt 3 PortThis USB-C hub expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for adding a thumb drive, external hard drive, digital camera, MP3 player and other USB peripherals. Connects Up to 4 USB-A PeripheralsFour USB-A ports accept USB peripherals, such as a flash drive, mouse, keyboard or printer, and all four provide up to 1.5A for charging smartphones and other mobile devices. All ports support fast USB 3.1 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with previous USB generations, so you can continue using older peripherals while getting highspeed performance from new devices.Note: Host must support USB OTG (On-the-Go)Built-In USB-C Cable Connects in Either Direction Connect the reversible USB-C plug to your source device’s Thunderbolt 3 or USB Type-C connector. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Ready to Use Right Out of the PackageThe plug-and-play USB 3.1 Type-C hub requires no software, drivers or external power. The lightweight case fits easily into a pocket, briefcase or laptop bag for connecting on the go. 3-Year Warranty and Environmentally Responsible DesignThe U460-004-4AB comes with a 3-year warranty. It’s manufactured in compliance with strict RoHS specifications, reflecting commitment to environmental responsibility. Specifications OVERVIEW UPC Code 037332209580 1/4 System Requirements Tablet, laptop, Chromebook, MacBook, smartphone or PC with USB-C or Thunderbolt 3 port. Package Includes U460-004-4AB 4-Port USB 3.1 Hub, 4x USB-A, Thunderbolt Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Type Hub Technology USB 3.x Host Connector USB C (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT Built-In Cable Length (ft.) 0.656 Built-In Cable Length (m) 0.2 Built-In Cable Length (in.) 7.87 Built-In Cable Length (cm) 20 Bus Powered Yes Product Length (in.) 11.7 Product Length (cm.) 29.72 Product Length (ft.) 0.98 Product Length (m) 0.3 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 0.7 USER INTERFACE, ALERTS & CONTROLS LED Indicators White (Connection to Power) CHARGING Total Charging Watts 7.5 Charging Ports USB-A: 5V 1.5A (7.5W) Charging Ports / Amps (4) 1.5A 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Plastic Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 1.06 x 3.00 x 5.70 Shipping Weight (lbs.) 0.20 Unit Dimensions (hwd / in.) 0.840 x 3.800 x 1.200 Unit Dimensions (hwd / cm) 2.14 x 9.65 x 3.05 Unit Packaging Type Box Unit Weight (lbs.) 0.09 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Relative Humidity 20% to 80% RH, Non-Condensing BTUs 2.4 BTU/Hr Power Provided to Connected Device(s) Up to 5V 1.5A (7.5W) per USB Port CONNECTIONS Number of Ports 4 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (4) USB 3.0 A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 4 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No Driver Required No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-004-4AB 价格&库存
很抱歉,暂时无法提供与“U460-004-4AB”相匹配的价格&库存,您可以联系我们找货
U460-004-4AB
    库存:9
