U460-004-4AB-C
U460-004-4AB-C
    TRIPPLITE
    4-PORT USB 3.1 HUB, 4X USB-A, TH
U460-004-4AB-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB-C Hub, USB 3.x (5Gbps), 4x USB-A Ports, 60W PD Charging, Black MODEL NUMBER: U460-004-4AB-C Highlights ● Supports USB 3.1 Gen 1 for fast data transfers up to 5 Gbps ● Accepts up to 4 USB peripherals, turning your laptop into a mini workstation ● USB-A fast-charging port provides up to 5V 1.5A (7.5W) of power ● Powers and charges PD Charging-compliant devices, such as MacBooks and Chromebooks ● Reversible USB-C plug connects in either direction for immediate no-fuss use Applications ● Charge your notebook or laptop by connecting its wall charger to the USB-C PD Charging port ● Transfer files to and from a USB thumb drive or external hard drive ● Attach a USB headset/microphone for recording your podcast ● Write a report using a USB keyboard with your tablet or Android smartphone USB 3.1 Type-C hub adds USB-A and USB-C charging ports to your laptop, MacBook, Chromebook or other compatible device. Features USB 3.1 Type-C Hub Connects to Your Device’s USB-C or Thunderbolt 3 PortThis USB-C hub with PD Charging expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for adding a thumb drive and other USB peripherals or powering and charging a PD Charging-compliant mobile device—all at the same time. System Requirements Connects Up to 4 USB-A PeripheralsFour USB-A ports accept USB peripherals, such as a flash drive, mouse, keyboard or printer, and the dedicated USB-A fast-charging port provides up to 5V 1.5A (7.5W) for charging smartphones and other mobile devices. All ports support fast USB 3.1 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with previous USB generations, so you can continue using older peripherals while getting high-speed performance from new devices. Note: Host must support USB OTG (On-the-Go). Charges a Connected DeviceThe USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook, Chromebook or Android smartphone) the USB-C hub is connected to. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 60W. Note: USB-C PD port does not support Quick Charge (QC). Built-In USB-C Cable Connects in Either DirectionConnect the reversible USB-C plug to your source device’s Thunderbolt 3 or USB Type-C connector. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Ready to Use Right Out of the PackageThe plug-and-play USB 3.1 Type-C hub requires no software, drivers or external power. The compact unit fits easily into a pocket, briefcase or laptop bag for connecting on the go. Specifications 1/4 ● Tablet, laptop, Chromebook, MacBook, smartphone or PC with USB-C or Thunderbolt 3 port Package Includes ● U460-004-4AB-C 4-Port USB 3.1 Hub, Black ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332209214 Technology USB 3.x Host Connector USB C (MALE) VIDEO Extended Mode No Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-C - USB 3.2 Gen 1 (5 Gbps) INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.2 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 CHARGING Total Charging Watts 60 Charging Ports USB-A: 5V 1.5A (7.5W); USB-C: 60W (20V 3A) Power Delivery (PD 2.0) Charging Ports / Amps 1.5A; 3A 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Plastic Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9mm Wire Gauge (AWG) 28/34 Shipping Dimensions (hwd / in.) 0.90 x 3.90 x 5.60 Shipping Weight (lbs.) 0.10 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Relative Humidity 10% to 90% RH, Non-Condensing BTUs 7.5 BTU/Hr Power Provided to Connected Device(s) Up to 20V 3A (60W) Input (USB-C), 5V 1.5A (7.5W) Output USB port, 5V 0.9A (4.5W) Output per USB port CONNECTIONS Number of Ports 5 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (4) USB 3.0 A (FEMALE) Side B - Connector 2 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Hub Ports Yes Number of USB Hub Ports 4 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Remote Wakeup Support No Driver Required No STANDARDS & COMPLIANCE TAA Compliant Option N Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-004-4AB-C 价格&库存
很抱歉,暂时无法提供与“U460-004-4AB-C”相匹配的价格&库存,您可以联系我们找货
U460-004-4AB-C
    库存:7
