VS450T
VS450T
    TRIPPLITE
    450VA 240W LINE-INTERACTIVE UPS
VS450T 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 450VA 240W Line-Interactive UPS with 4 Outlets AVR, VS Series, 120V, 50/60 Hz, Tower Highlights ● Protects valuable equipment from dangers posed by brownouts, surges and line noise ● AVR battery backup allows time to save files and safely shut down during blackouts ● 4 NEMA 5-15R outlets provide power to PC, home theater or digital signage equipment ● Alarm and front-panel LEDs report online, battery, fault and overload conditions ● High 95% efficiency with low BTU ratings saves power and lowers your energy costs MODEL NUMBER: VS450T Applications Line-interactive UPS provides basic battery backup with AVR protection for your office computer, home theater setup or digital signage. Features 450VA/240W/120V Battery Backup for PCs, Home Theater or Digital SignageThis 120V UPS with AVR protection provides reliable battery backup and AC power protection against blackouts, brownouts, surges and line noise that can damage valuable electronics or destroy data. The four-outlet 120V battery backup is ideal protection for your home office, media center or commerce components, including computers, routers, printers, HDTVs, Blu-ray players, game consoles, ATMs, security systems and digital signage equipment. Allows Time to Back Up Critical Files During a BlackoutBackup support allows you to work through short power failures, and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the line-interactive UPS system should keep an energy-efficient desktop computer with small LCD monitor powered as long as 17 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. Connects Your Equipment to 4 NEMA 5-15R OutletsThree 5-15R outlets provide both battery backup and surge protection for your computer, monitor and other crucial components. The other 5-15R outlet is surge-protected only for printers, scanners and other non-essential equipment. A high 95% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. Automatic Voltage Regulation (AVR) Corrects Low-Voltage ConditionsAVR protects your equipment from incremental hardware damage, data loss and performance problems caused by brownouts. The VS450T can correct brownouts as low as 89V and overvoltages as high as 145V back to nominal 120V power without drawing on the battery backup needed to support your equipment during a blackout. 316 Joules Fight Back Against Unexpected Power SurgesA 316-joule surge suppression rating protects connected components from the harmful effects of power surges. Combats Electromagnetic Interference That Can Harm EquipmentVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The VS450T incorporates technology that filters out disruptive 1/5 ● Protect your PC and other sensitive electronics against power surges, brownouts and blackouts ● Operate essential equipment during short-term power outages using battery backup power ● Shut down PCs, DVRs, routers and other equipment without data loss during long-term power outages Package Includes ● VS450T 450VA 240W LineInteractive UPS with 4 Outlets ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States line noise so that it won’t affect your equipment. Easy-to-Read LEDs Report Real-Time UPS and Power StatusThree front-panel LED indicators monitor essential information, such as online, battery and fault modes. An audible alarm will sound in case of low battery, excessive load and fault condition. Tower Form Factor for Easy Placement in Your Workspace or Media CenterThe long-lasting ABS housing fits easily on a desktop, shelf or anywhere else convenient to your workstation or home theater. The five-foot power cord with NEMA 5-15P plug connects to a properly grounded AC wall outlet. Specifications OVERVIEW UPC Code 037332212887 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 5A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 5A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 450 Output Capacity (kVA) 0.45 Output Capacity (Watts) 240 Output Capacity (kW) 0.24 Output Capacity Details 3.8A @ 120V. (LINE MODE) 110%+/- 10% @ 5 minutes; (BATTERY MODE) 110% +/- 10% @ 5 seconds Power Factor 0.53 Nominal Voltage Details 120V sinusoidal in line mode and 120V PWM in battery mode Frequency Compatibility 60 Hz Frequency Compatibility Details Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. Output Voltage Regulation (Line Mode) 120V (+9%, -12%) Output Voltage Regulation (Battery Mode) 120V (+/- 10%) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 1 surge-only outlet Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (4) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 0.5 min. (240W) Runtime Half Load (min.) 5 min. (120W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 8 hours (10% to 90%) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 89 to 145 Overvoltage Correction Input voltages between 132 and 145 are reduced by 15% Undervoltage Correction Input voltages between 89 and 108 are boosted by 18% USER INTERFACE, ALERTS & CONTROLS Switches Controls off/on power status Audible Alarm Audible alarm indicates low-battery, fault, overload and replace-battery status LED Indicators 3 LEDs indicate online mode (green), battery mode (yellow) and fault mode (red) SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 300 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Height (mm) 142 Primary UPS Width (mm) 102 Shipping Dimensions (hwd / in.) 8.70 x 5.50 x 13.50 Shipping Weight (kg) 3.99 UPS Housing Material ABS UPS Power Module Dimensions (hwd, in.) 5.6 x 4 x 11.8 UPS Power Module Weight (kg) 3.72 UPS Power Module Weight (lbs.) 8.2 Unit Weight (lbs.) 8.200 Unit Weight (kg) 3.72 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 23 AC Mode Efficiency Rating (100% Load) 95% AC Economy Mode Efficiency Rating (100% Load) 0.95 Operating Elevation (ft.) 6561 ft. (2000 m) above sea level COMMUNICATIONS Network Management Card Description Network management not supported Communications Interface None LINE / BATTERY TRANSFER Transfer Time 6 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 89 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS High Availability UPS Features Automatic Voltage Regulation (AVR); Surge/noise protection APPLICATIONS UPS Applications Home/Office Desktop; Retail/Point of Sale; Hospitality 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
VS450T 价格&库存
很抱歉,暂时无法提供与“VS450T”相匹配的价格&库存,您可以联系我们找货
